sway bar noise
Old Feb 17, 2002 | 08:49 AM
maxman00's Avatar
sway bar noise
I have a 00 max with addco sway bar and whenever I have 1 or more people in the back it tends to make a bottoming out noise when going over bumps. I have been told that is normal, but I highly doubt that is the case. Any opinions?
Old Feb 17, 2002 | 10:08 AM
BigDogJonx's Avatar
Re: sway bar noise
What do you mean bottoming out noise? Like the bar is actually scraping the ground?
I would check the bar, make sure you dont see the road scrapes on the bottom of it, if you do, then yeah, you bottoming it out.
Dixit
Old Feb 17, 2002 | 10:34 AM
max'n out's Avatar
my guess is it's to close to the axle and it's hitting.
Old Feb 17, 2002 | 11:03 AM
Greg's2kGLE's Avatar
Yea but the RSB is attached to the rear axle, so hoe could it move. My guess would be the bushings, sometimes I hear that sound too with more that on person in the back.
Old Feb 17, 2002 | 11:15 AM
Sly's Avatar
Sly
You're not bottoming out. What's happening is the passenger side bracket that attaches the RSB mid section to the rear axle extends out just far enough to catch the lateral link when the suspension is compressed enough. This results in a "clunk" sound as it scrapes past.
You have two options to fix this. First option is to take the bracket off and trim the end down to provide more clearance. Second option is to simply slide the mid section brackets further inboard so the passenger side one doesn't interefere anymore.
Old Feb 17, 2002 | 02:09 PM
maxman00's Avatar
Thanks a bunch for the info!!! I am going to do just what you said. I really did not want to take the thing off!
Old Feb 17, 2002 | 02:32 PM
irvine78's Avatar
when i go over a speed bump just a little too fast...it makes that clunking noise too...i checked the sway bar, and it's fine..beats me too..
Old Feb 18, 2002 | 12:55 AM
bernie2000se's Avatar
Sly, has the exact answer, I just finished with mine(addco) same thing was happening, also what we did was move the bushings(right side) about 6-8 inches in towards the center of the car, plus move the top u bolt over about 1 inch, works great now no more bottoming out sound( i know exactly what you mean) matter of fact i posted almost word for word what you did about 2 weeks ago. Bernie
Old Feb 18, 2002 | 06:43 AM
maxman00's Avatar
thanks for all your advise! I will let you know how it comes out.
Old Feb 18, 2002 | 11:02 AM
maxman00's Avatar
Sweet! It seems to have worked! Now I can load my car down with a bunch of drunk slobs (my friends) and not loose my mind when I go over bumps I was getting sick of them calling my max a piece of s**t!!!
thanks
Bill
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
