brakepad longevity
Old Feb 17, 2002 | 12:28 PM
cory's Avatar
brakepad longevity
can anybody tell me how long the brake pads will last on my 2000 SE with 17" wheels?
Old Feb 17, 2002 | 12:31 PM
BigDogJonx's Avatar
Re: brakepad longevity
well on my last 2000 maxima se I had the 17" wheels also and put about 35k on it before I traded it in for a 2001, but I remember checking the pads, and it looks liked it had still another 15k-20k left. I say at least 50k.
Dixit
Old Feb 17, 2002 | 12:37 PM
Dave Lopez's Avatar
I just took my car in to the dealer for its 15,000 mile service(ive had the car for almost 2 years). According to the mechanic, I have 75% of the pads left. At this rate, ill go almost 6 yrs or 60,000 without having to change the brake pads
Old Feb 17, 2002 | 01:25 PM
Wizeguy's Avatar
I'm still on the stock pads, I'm going to change them out this spring 1995 SE 105,000 miles.
Old Feb 17, 2002 | 02:52 PM
Y2KMaxGXE-R's Avatar
damn guys these are good news. I remember the days I had to change pads on my prev car (93Gr Prix) every 15-20K mi or so..How much do stock pads cost?
Old Feb 17, 2002 | 02:56 PM
cory's Avatar
I ordered front and rear pads for my 2000 SE from tropy nissan (lost website but search engine will find). I paid $88 plus $8 shipping for front and rear total.
Old Feb 17, 2002 | 03:24 PM
thats not bad at all. what about OEM rotors? Man, I hated Gr Prix brakes so much, GR Prix had defective calipers, I had to change rotors (120 each) and pads were gone so soon..Never buy brake parts from your neighborhood auto parts store.
Old Feb 17, 2002 | 04:12 PM
bert's Avatar
I just had my rears done (20% left but on the screamers) (58K KM, 30K miles) the fronts have another 40% left. I am sure if I would have been easier on them they would have lasted longer. Other 2K+ owners have also mentioned that the rears wear faster.
Old Feb 17, 2002 | 05:57 PM
radpp16's Avatar
If the brake pads are so good then...
Ok then...
I have 21.5 k miles on my max. I am not braking like i used to brake.. I have to depress the brake pedal ALOT more, almost touching the floor. If its not the brake pads causing this problem, then what is. I remember when i first got the car, the braking was tight, i was scared to touch the brake pedal cause it was so tight and responsive.
This is a good thread, all comes coincendentally when i am bout to buy the front Metal Matrix brake pads..should I?
PLease reply or email me if you know what i should do? check? service?
Roger
Old Feb 17, 2002 | 07:54 PM
2M0A0X2's Avatar
Re: Re: brakepad longevity
Dixit
why did you trade your 2kin for a 2k1?
Old Feb 17, 2002 | 08:23 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
radpp16- i had the same problem with my 2k1 ae. when i got it with about 100 miles on it, the brakes felt strong but after 8500 the pedal was about at the floor even under normal braking. i started getting judder when braking from high speeds so i took it and my rotors were warped and the pads were of course shot. they replaced both and now everything feels fine. i would pump the brake when the car isnt turned on and see if it can hold the pressure after a a few days, i would take it somewhere to check the rotors.
Old Feb 17, 2002 | 08:35 PM
Max_5gen's Avatar
Re: If the brake pads are so good then...
Originally posted by radpp16
Ok then...
Roger
1. Don't know for sure, but their wear doesn't cause "low brake pedal" - probably, you've got air in brake lines. Make a simple test - when the engine is OFF depress brake pedal several times - it has to get firmer with each time and after 3-4 depressings feel really hard, like a brick. If it doesn't - you most likely have air in the lines - bleed them and repeat the test.
2. Check your brake pads anyway, especially rears if they're stock. Mine was gone after 10 k miles if I recall correctly.
Mike.
Old Feb 17, 2002 | 08:43 PM
radpp16's Avatar
hey thanks for the replies, i was starting to think everyone on this forum were bunch of non replying *****. lol
I am gonna do the test right now.. its midnight lol
ROger
Old Feb 17, 2002 | 09:09 PM
BigDogJonx's Avatar
Re: Re: Re: brakepad longevity
Got 20k for my 2K and the APR dropped to 3.9%
Dixit
Old Feb 17, 2002 | 09:37 PM
2001SE's Avatar
Re: Re: Re: Re: brakepad longevity
Dixit
why not do it again for the 2k2...if you did it for the 2k1 so why not 2k2?
Old Feb 18, 2002 | 12:22 PM
cory's Avatar
Ok then...
Roger
Have you checked your brake fluid? Low brake fluid requires the pedal to be pressed further to engage the brakes.
Aaron
Dec 25, 2002 12:50 PM
MAXSRB
Oct 18, 2002 03:59 PM
97MaxGurl
Oct 15, 2002 02:15 PM
97MaxGurl
Sep 19, 2002 03:45 PM
