Is there an ECU limiter removal for my lowly GXE?
I was on the freeway the other night and I tried to test the top speed and I hit the limiter at around 133. I really didn't like the feel of hitting the limiter. Is there any way of getting rid of it for the 5th gen? Why did nissan put the limiter on just the GXE? Should I put my nitrous kit on so that I can bust right through the limiter?
Re: Is there an ECU limiter removal for my lowly GXE?
Jet chips has one for $399, but outside of taking off your limiter I don't know what it does. Also I don't think any 5th Gen's have tried it so maybe you could be the ginuea pig for us all.
As far as the NOS goes; bad idea and less you want to blow the motor. Then besides asking about a chip to take your limiter off you'll be
about your blown motor. Hope this helps and good luck on the chip.
Thanks for noticing my joke knuckleheads on the NOS busting through the limiter. So I guess that there is nothing to do about my problem. So what is this crap about the NOS? Isn't everything bad for your car(Like SC?)?
I would think that hitting speed limiter and have your car run lean while running nitrous will blow up your engine for sure...
Max
What the heck is that Kev?
Originally posted by Y2KevSE
http://www.rev-industries.com/apexih...speedmeter.htm
Kev
Are you saying that this device eliminates the rev limiter without having to replace the whole ECU?!?!? Hmmmm
Deac
Re: What the heck is that Kev?
Originally posted by Deac
Kev
Deac
Kev
Deac
Kev
Deac
Kev
Deac
Re: Re: What the heck is that Kev?
Originally posted by ajahearn
I'm curious as well about the APEXi Rev/Meter. From their web site it sounds like it sends a lower RPM signal to the ECU than actual. Presumably you would then have to read the real RPM's from the APEXi. So where can you find the "real" ratings for the engine and transmissions? Thanks.
Originally posted by Y2KMaxGXE-R
a little OT but someone here said that GXE with manual do not have a speed limiter..who was it that run 155? Irvin78?
He's one of the lucky ones that don't have a limiter..... or maybe he was too drunk to and couldn't read the numbers correctly.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Dasmith
Sep 23, 2015 08:28 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
