moded 2k1 v.s. 2k2......
Re: moded 2k1 v.s. 2k2......
[QUOTE]Originally posted by maxgsxr1
[B]with my mods , will my car match a stock 2k2 at highway speeds? say 70 or 80 mph on.......i'm asking this because i work at a infiniti dealer and the i35 feels about the same pull at highway speeds.but not at the start off. (i don't have that awesome torque!) has anyone done the race with my mods?
Ok i'll answer you question with a question. Can you beat a stock 2k1 Maxima 5spd? If the answer is yes; then yes you probably could beat 2k2 w/auto or at least give it a run for it's money. If the answer is no then you are going to get wasted. As for the 2k2 6spd; for get about it; you'll get blown away easily. Hope this helps to answer your question, but if you do meet up with a 2k2 auto or 6spd run him or her and tell us what happens. Also from one automagic to another good luck
i'm talking about a race from 70 or 80 mph on......my modded max against a stock 2k2? both auto
with my mods , will my car match a 2k2 at highway speeds? say 70 or 80 mph on............?
so...... NO
Originally posted by unrealii
A 2k/2k1 5 speed can beat an auto 2k2. If you can beat the 5 speed, then you should be able to beat the 2k2. I hope that helps
http://forums.maxima.org/showthread....&highlight=060
Originally posted by mattattax
really? that's news to me--what does the 5 sp. run the 1/4 in? i thought the 5 sp. ran 14.7 or 14.8 i don't doubt that it could happen but i am skepticle
Re: Re: moded 2k1 v.s. 2k2......
Originally posted by dmbmaxima88
i raced QUANSUNG on the highway and he has intake, catback, y-pipe and i was stock and well from any speed, 20-80, 70-130 it was all me by a good margin.
so...... NO
so...... NO
Originally posted by motectransam
A decent indicator hwy roll-on ability is quarter-mile trap speeds. Stock '01 automatics do about 87-88mph. Stock '02 automatics do 94-95mph (and 6-speeds are faster yet). To pair the 6-8mph trap speed difference you need tremendous amounts of work. You could get there by a full street cylinder head porting job, a mild street cam, remapped shiftpoints, and a built trans with high stall (drag launch only, not highway roll-on as you stated) lockup torque convertor. A peaky centrifugal blower making 6-7psi boost with a fairly high stall torque convertor can do that. Or a positive displacement blower (nobody makes one yet) with 4.5 psi non-intercooled boost with stock stall speed torque convertor can also do the job. No matter which way you go, you have to build up that automatic transmission to handle the output.
Re: Re: Re: Re: moded 2k1 v.s. 2k2......
me 2
so 2k-2k1 5speeds are ~14.6-14.7 and 2k2 autos are ~14.5-14.6?
me 2
2k-2k1 5-spd are 14.8~15.1 stock and 2k2 autos are 14.6~14.9 stock.
TallTom
50
07-08-2022 09:54 AM
pktaske
09-04-2015 08:40 AM
