SC Grinding noise...the saga continues
SC Grinding noise...the sags continues
When I'm at idle, I hear like a grinding noise, when I hit the gas, it goes away...I was low on oil and I still have'nt changed it yet, I have a leak. But when my oil pressure goes up (oil pressure gauge) the noise stops! It was suggested that its not getting enough oil to lubricate the SC so it grinds when your at idle and the oil pressure drops...when I rev and the rpms and oil pressure goes up, the noise stops! Oil or could it be something else? Anyone else experience this? Holla...
Deac
Deac
Re: SC Grinding noise...the sags continues
Deac
Deac
well...
Originally posted by max'n out
YES
YES
Re: well...
I have an oil leak, so once I get it fixed, I will fill up with oil and see if it goes away. i called Vortech and they say if it persists, I have to send it in! Wanted to see if anyone else has experienced this!
Deac
Deac
Re: Re: SC Grinding noise...the sags continues
Originally posted by The New CLIMAX
I used to hear a noise in my SC when my pressure would drop too about 30-32PSI, and when it would go to aobut 34-36 it would not make the noise, not sure if it was a grinding sound but one could hear it. Then when I placed the Walbro fuel pump and took away the stillen Aux pump, I have not heard the problem, and my PSI has been at 50PSI. Hope this helps.
Deac
DC_Juggernaut
09-28-2015 04:07 PM
carlosvq30
09-26-2015 09:44 AM
