Simple Bose modification?
Any simple way to add a regular speaker to the back deck to give a more "surround sound"? Even with adjusting the fade to add more sound to the rear, the sound seems to mostly come from the front of the car. Can a speaker to run off the base unit in the rear deck? (My 95 Max Bose sounded so much better because the rear speakers were in the deck instead of the rear doors like the 2000 I30)
Thanks.
Thanks.
Re: Good idea, but how?
Originally posted by sascuderi
Adding two tweaters would give the surround effect, but can it be done? Can they be connected to the base unit?
as far as i kno.. and i dont know that much... all of bose's speakers for the bose-optioned maxima are self amplified... so the only thing you need is to run a power/ground wire from your back door speakers into the C pillar where you might mount your tweeters .. since bose systems arent usually compatable, .you might want to purchase the same tweeters you have on the A pillar. just my thoughts
Apr 16, 2020 05:15 AM
