2k2 6 speed fluid question.
Old Mar 2, 2002 | 01:43 PM
freeze2k2's Avatar
So i changed my 99 fluid when it was new to the redline mtl, man what a difference. To get the old fluid out, it had to be de-vacced(sucked out). My dealer told me today that the 6 speed has a drain plug and doesnt have to be de-vacced. Anyone know for sure before i get under my car?
Old Mar 2, 2002 | 01:50 PM
20 MAXIMA 02's Avatar
Re: 2k2 6 speed fluid question.
not i ... but keep us 6 speeders updated
Old Mar 2, 2002 | 04:27 PM
TellschMax02's Avatar
What a great topic...I just got done changing my trans fluid . First off, use MT-90 and not MTL. MT-90 matches the required viscosity rating for the Max.
There are 2 bots (size 10 hex head) located on the driver side of the trans…a high one and a low one. Take off the high bolt (fill plug) first...then take out the low one (drain plug). Be careful because the fluid comes out fast (I got it everywhere ).
Once it is all drained out, screw the drain bolt back in. You will need a funnel with a hose attached (a rather long hose at that) and start filling the trans. The service manual says its needs 4 and 7/8 pints, which equals 2.438 quarts. Fill it up till it over flows...let it over flow, then plug her up and your done.
No vacuum...no problems!!
I haven't had a chance to drive it yet (blizzard here), but I am looking forward to it.
Good Luck!!
Brian
Old Mar 2, 2002 | 04:53 PM
freeze2k2's Avatar
Re: Re: 2k2 6 speed fluid question.
Good Luck!!
good job.
Brian
Old Mar 2, 2002 | 07:24 PM
ABS's Avatar
ABS
Does anyone know what the best fluid to use is? I know it should be a 90 weight, but I am afraid to go with synthetics. In my 95' Civic, I put in synthetic saw an increase in fuel economy but I also started to lightly grind synchros on fast shifts. In the 2K2 Maxima, I already feel the synchros catching a little on shifts into 2nd and 3rd. So, does it make sense to go to a synthetic like Redline or Mobil 1 for 6 speed tranny?
Old Mar 2, 2002 | 08:13 PM
I can get back to you next week about MT90 in a 2k2...but from my experiences Redline does nothing but help. So far so good...
Synthetics are a good thing...
Brian
Old Mar 3, 2002 | 05:20 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya i switched over at 1500 miles and WOW what a difference best 30 bucks i ever spent on my car. MT-90 IS THE WAY TO GO.
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Mar 29, 2016 11:08 AM
knight_yyz
Nov 1, 2015 01:34 PM
Need help
23
Oct 2, 2015 08:56 AM
