what is the lifespan of a supercharger????
Old Mar 3, 2002 | 11:18 PM
a33's Avatar
a33
my friend has a super charger with 90000 km(roughly 60000miles) on it
will it breakdown soon???
Old Mar 4, 2002 | 12:19 AM
RBa's Avatar
RBa
Re: what is the lifespan of a supercharger????
Hello!!..
I also would like to know this too...
Old Mar 4, 2002 | 04:48 AM
zeitgeist57's Avatar
Depending on usage and oil use (some are fed oil through the engine, some use ATF in the supercharger that needs to be changed every so often) supachargers should run for a LONG time...I wouldn't say lifetime, but 100,000miles isn't unreasonable to expect from a mostly street driven supacharger.
If it gets NOISY....it might be on it's way out. Time for a new one, or a rebuild.
Old Mar 4, 2002 | 05:07 AM
s1rch's Avatar
If properly taken care of I don't know if mileage can be documented.
As far as time, definitely over 3 years.
birth certificate
Old Mar 4, 2002 | 06:16 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
If it does breakdown, send it to Vortech to have it rebuilt.
Old Mar 4, 2002 | 06:24 AM
190hpKiLLA's Avatar
Granny Driven
Vic told me a while ago that SC needs to be rebuilt every 100K miles.
Old Mar 4, 2002 | 09:40 PM
a33's Avatar
a33
my friend has 60000 miles but he did run the 5.5 psi of boost that came with the charger.... he ran 7psi most of the time and 9 for a little while....
his charger seems loud all the time,,,, there is a high pitched noise from it all the time, once you start the car, the noise comes......
kev: how much will it cost to rebuild the charger?????
and would the high pitch be because my friend is using a 4th gen charger on the 5th gen???
Old Mar 5, 2002 | 10:05 AM
RB26DETT's Avatar
tell your 'friend' to post some pics.
sounds like a v1 in a 5th gen.
Old Mar 5, 2002 | 10:16 AM
Y2KevSE's Avatar
Is this the infamous white 5th gen with a Ninja kit?
4th gen blowers can be the same as 5th gen blowers... if he used Vortech V2.
Think you can get a sound file?
Contact Vortech: http://www.vortechsuperchargers.com to get a quote. I *think* the rebuild is about $400.
Old Mar 5, 2002 | 11:33 AM
a33's Avatar
a33
thats right kev
that is the white one with the ninja kit
i believe he has a 4th gen v1 supercharge.........
i ll try to get a video of his car or something.......
what is the biggest difference between v1 and v2, how can i tell????
i believe his is a v1 cuz he got it in 1999
Old Mar 5, 2002 | 04:23 PM
Y2KevSE's Avatar
thats right kev
All 5th gen supercharger kits should be V2, unless he somehow got a V1 with the kit.
Look at the supercharger label... it should say V1 or V2.
Old Mar 5, 2002 | 04:31 PM
a33's Avatar
a33
i am pretty sure his is a v1, cuz he bought it off his friend which had a 98 or 99 i30
Old Mar 6, 2002 | 01:22 AM
a33's Avatar
a33
do u know what will have to replaced soon????
pulleys??? belts??????
what is involved in a rebuild from vortech???
Old Mar 6, 2002 | 06:15 AM
Y2KevSE's Avatar
V1 off a 99 or 98? The kit won't work if he did that because the piping is completely different... even down to the holes for the MAF tube (4th gen MAF bolt holes have a rectangular pattern, 5th gen MAF bolt holes have a square pattern). Unless he had a shop make them for him, it should be a V2 kit for a 2000 Max.
Internals of the blower.
Old Mar 6, 2002 | 06:04 PM
a33's Avatar
a33
is it necessary to move the wind shield washer holder when installing the charger?????
i remember that he moved the stuff in the engine compartment around just to fit the supercharger, i am sure he has a v1, cuz he bought it off his friend's 98-99 i30.....
and he did bring it to a shop to install...
Old Mar 7, 2002 | 06:31 AM
Y2KevSE's Avatar
No, it's not required.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
pears
Sep 18, 2015 05:25 AM
Cumalot
Nov 28, 2000 09:38 AM
