Problems with 2k2 clutch anyone?
Old Mar 4, 2002 | 09:48 PM
Newman's Avatar
this is the first manual car i have ever owned so im still learning whats normal and what isnt.
The other day i noticed that my shifter slipped out of third when i lightly hit it with my arm even though my foot was off the clutch. i wasnt sure if it really happened like that so i ignored it. tonight the same thing happened and i tested it in 2nd and it did the same thing with hardly any pressure at all and with my foot no where near the clutch. so i pull into my driveway and turned the car off and pulled the ebrake so i dont go anywhere. WITHOUT MY FOOT ON THE CLUTCH AT ALL i was able to shift into 1st, out of first, into second, out of second, into third, out of third, and into forth and out of forth. i wasnt able to go into 5th or 6th like this. i was shifting as softly as i would while pressing the clutch and the shifter went into gear just as easily as well. whats the deal? first of all, i just want to make sure that this is not normal and that this is in fact a problems. if so, is anyone else able to do this?
Old Mar 4, 2002 | 09:54 PM
Dany's Avatar
Re: Problems with 2k2 clutch anyone?
I didn't try doing it, but I don't think it should do that.
I didn't notice any problems with 6-speed so far.
Old Mar 5, 2002 | 12:14 AM
TimW's Avatar
The silent but deadly Moderator
search back a few days..
I think 2 or 3 2k2 owners have had syncro problems.
Old Mar 5, 2002 | 02:01 AM
littledog's Avatar
You can always pop out of gears without depressing the clutch. But it should require a bit more force than you described. Also, it's normal for you to shift into and out of gears when the car's turned off. The engine nor the wheels are rolling so you do not need the clutch to synchronize the gears for you to put it into a gear.
Old Mar 5, 2002 | 08:40 AM
Newman's Avatar
well thats good to hear bu then why cant i shift into 5th or 6th?
Old Mar 5, 2002 | 10:25 AM
emax02's Avatar
Everything you just said is completly normal. When parked any manual car can go threw the gears. When you bump the shifter and it pops out thats normal too. In fact I pop my car into nuetral all the time with out using the clutch, it is degigned that way for a reason.
Old Mar 5, 2002 | 10:38 AM
Dave B's Avatar
Not DAVEB the parts guy
You can go into all the gears. Park the car on level ground so you can't roll, take the e-brake off, psuh the clutch in to reduce the bind on the tranny and motor, release the clutch. After that you should be able to shift into all the gears without the clutch.
Dave
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
