How to remove the middle air vents?
Old Mar 5, 2002 | 10:38 PM
PhatGuy
Has anyone removed the middle air vents? If so how did you so it without any problems?
I wanna fix the rattle in the middle dash between the vents and the clock. I realize I'm not the only one who has had this problem. Anyone who has how did you fix it?
Old Mar 5, 2002 | 10:44 PM
2000MaximaSE's Avatar
Re: How to remove the middle air vents?
Its easy, put your fingers in the vent pull up and out like diagonal towards the overhead light once it pops loose yank the shiet out of it..
Adam
Old Mar 5, 2002 | 10:48 PM
chinaonnitrous1's Avatar
just give it a good yank...make sure your not holding onto the air loveurs...or whatever..its the part that moves up and down to direct the air..just pry it out from the top to loosen it..and grab it from the bottom..theres like 4 clips that hold it in
Old Mar 6, 2002 | 04:54 AM
Colonel's Avatar
Old Fuddy Duddy
And for gods sake DONT use a screwdriver like the idiot service guy did on mine...they ended up having to order a new radio after gouging the top right corner with the screwdriver.
Old Mar 6, 2002 | 05:03 AM
PhatGuy
Thanks for the tip! What do you suggest?
Old Mar 6, 2002 | 05:24 AM
Colonel's Avatar
Old Fuddy Duddy
According to the ESM (and my experience) the suggestions above work. Just get your fingers in the top of the vent area and give a good tug. You'll hear it pop and then kinda wiggle it out. The diagonal is a good suggestion. And do be careful of the moveable vents things...easy to miss, break and then REALLY get mad.
Old Mar 6, 2002 | 05:27 AM
PhatGuy
Thanks!
Has anyone else had that rattle on the middle dash between the vent and the clock?
DJLAX152
May 4, 2021 11:46 AM
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
lux97Max
Sep 4, 2015 05:42 PM
