Need To Know What To Do.....Install My H&R Springs on stock struts or buy The AGX???
Old Mar 10, 2002 | 05:29 PM
K Pazzo 6's Avatar
I have 15k miles on my car...should I install the H&R springs on w/ my stock struts still struts wear out? Or should I buy the modified AGX Struts that cattman sells? Need your input....Also what so good about the AGX that I hear alot & whats it good for? Thanks ahead for the help!
Old Mar 10, 2002 | 05:41 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
the agx's are plug and play, very very good, easy to adjust while they are on the car, and last for a long time. don't lower the car without them..
Old Mar 10, 2002 | 05:49 PM
K Pazzo 6's Avatar
I'm not too familar w/ all this....but you say 'easy to adjust'...whats the point or reason for adjusting?
Old Mar 10, 2002 | 05:53 PM
you can adjust the stiffen of them, from soft to hard, hard will be harsher to ride on but handle better.
Old Mar 10, 2002 | 07:18 PM
Dany's Avatar
I am planning to do the same thing, install H&Rs on my car, but I am going to use stock shocks.
I used to have H&Rs on my 95 Maxima with Tokicos and Tokicos sucked so bad. So I don't know about other after market shocks.
I don't know much about AGX, but I definetly don't need that adjusting stuff.
There are people here on the .org that have lowered their car with H&Rs and used their stock shocks, and they say car rides fine on stock shocks. No problems.
Old Mar 10, 2002 | 09:41 PM
Greek to the Max's Avatar
Im installing with stock SE struts/shocks. If you dont need the added stiffness and performance, stay stock. Some people are lasting 45-50 miles on stock.
Old Mar 11, 2002 | 04:39 AM
please don't lower your cars on stock shocks, it's jjust not right, mine on my 95 blew after about 100 miles, i drove to maxus (400miles each way) with a dead rear and a dying rear shock, not fun. i got toks after that, they were better but not the greatest, they work, but this time it's AGX's baby. it's not worth the efffort to reinstall stuff a second tiem when you have to replace teh springs.
Old Mar 11, 2002 | 07:35 AM
See, you talk about wasting money, AGX's are a laugh to. Listen, find me a 5th gen Se driver who's shocks blew out that fast.
Old Mar 11, 2002 | 09:42 AM
PapaTango's Avatar
Greek,
So are you saying that the 5th Gen shocks are higher quality than previous generations? Just curious, I also want to put on a set of H&R springs on my '02 SE but don't really want/need the adjustibility of the AGX's. I just want to get the car down a couple of inches.
Old Mar 11, 2002 | 11:14 AM
acMAX's Avatar
I've had HR's on my car for the last 8k miles or so and I'm on stock struts too.
No problems yet and the car handles great but I've heard that your stock struts will wear down faster with the aftermarket springs..
Old Mar 11, 2002 | 01:12 PM
PapaTango's Avatar
Originally posted by acMAX
...I've heard that your stock struts will wear down faster with the aftermarket springs..
Is this because there is a greater danger of bottoming out the shock strut and thus causing internal damage because of the shorter springs? It seems to me that even with the shorter, stiffer sport springs (at least those with a reasonable amount of lowering) you will work the stock strut in the middle to lower end of strut compression but still within it's compression limits. Assuming of course, you avoid the major road craters as much as possible.
Isn't there a bump stop/cushion on the stock strut/spring setup designed to prevent the strut from being compressed past its design limits?
Is this bump stop/cushion modified in any way when shorter springs are installed?
Old Mar 11, 2002 | 06:50 PM
zman187's Avatar
On the KYB AGX's are the front and the back both plug and play, cause i'm pressed for money so the install would be done myself with friends. I've already done the fronts and i plan to do the rear with progress springs and i'm going to just wait for the new struts does anyone have any tips for me on the rears it looks a lot more complex than the fronts
Old Mar 11, 2002 | 07:11 PM
Originally posted by PapaTango
Greek,
2 inches eh, well you are asking for alot. All I have learned from my searches is that SE Shock & Struts and stronger and spotier then the other models, thus explaining why they last longer with aftermarket springs. Mind you, going higher then 2 inches is asking for alot from any stock unit.
Old Mar 12, 2002 | 07:05 PM
PapaTango's Avatar
Agree. "A couple of inches" was a generalization on my part. I really don't need to go any lower than what a set of H&R's will give me.
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
