2k2 oil filter
Old Mar 17, 2002 | 10:00 AM
GimmeTorq's Avatar
2k2 oil filter
Went to a dealership to buy couple oil filter for my 2k2. They gave me two with part number 15208-9E000. When I got home, I went under my Max and observed that the part number in the from-the-factory oil filter is different, 15208-65F01.
Could this be because one is probably "made in Japan", while the other one is "made in USA"? Are these filters compatible?
I will probably go back to the dealer to ask before I attempt to use them, but I was wondering if anybody has used the filter with p/n 15208-9E000 will fit.
Old Mar 17, 2002 | 10:56 AM
freeze2k2's Avatar
hmmmm
Old Mar 17, 2002 | 11:01 AM
emax02's Avatar
Re: 2k2 oil filter
I heard about this before, it's normal I think. The filters you bought should fit.
Old Mar 17, 2002 | 12:59 PM
GregP's Avatar
The filters they gave you will fit, but the manufacturer's part number for the 2K2 Max is the 65F01 number, or 65F00. The only difference is that the 65F00/01 filters are shorter. Both will work.
Greg
Old Mar 17, 2002 | 01:17 PM
GimmeTorq's Avatar
Thanks!
Cool! Thanks for the info. Actually if the 9E000 is longer, it may have a larger filtering area, which is most likely a good thing. Thanks again.
Old Mar 17, 2002 | 01:58 PM
GregP's Avatar
Re: Thanks!
FYI also, the 65F00/01 filters are the same ones spec'ed for the 2001/2002 Pathfinder with the VQ35 engine.
Interesing that Nissan designs a bigger engine, yet the oil filters are smaller and the manual trans. fluid capacity is half that of the cars with the VQ30 !!!
TallTom
57
Oct 14, 2025 05:16 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
