so. what's the answer to water in the clear side markers?
Old Mar 17, 2002 | 02:54 PM
radpp16's Avatar
Ive used SEARCH to find threads on this but no luck.
Has anyone got an answer to get the moisture out of the clear side markers? NO I DONT WANT TO BUY A NEW PAIR.
Roger
Old Mar 17, 2002 | 03:05 PM
Norm02SE's Avatar
Hello.Ive read something about sealing the new markers with silicon.I belive the instruction are at 5thgenmaxima.com or custommaxima.com.If I can find them I will send it to you.I just ordered my clear markers 5 minutes ago and I do not want to have that probem also.By the way,how do they look.Ive got a 2k2 sterling mist and they should look pretty sharp.Also did you put red bulbs in the rear and if so where did you get them.Thanks and good luck.
Old Mar 17, 2002 | 03:18 PM
radpp16's Avatar
yeah def silicone
I got the bulbs from
polarg 194 wedge red bulbs i believe9. 10 bucks for 2 bulbs. I bought them from a local rice shop. I was contemplating getting superwhite wedge bulbs, but then again... no
Roger
Old Mar 17, 2002 | 06:32 PM
PCGuRu2K's Avatar
When I first installed my clears I didn't bother putting on silicone to seal out the moisture. Because of this there was a sh*itload of moisture in them. They recently got stolen off my ride so I bought new ones. This time I took the time to properly seal them with some clear silicone. Even since then not one drop of moisture. I would definitely recommend taking the time to carefully seal them properly.. They look better with no moisture in them
Old Mar 17, 2002 | 07:52 PM
Norm02SE's Avatar
HEY RADPP16.THE WRITE UP ON THE CLEARS WITH SILICON IS AT 5THGENMAXIMAS.COM.ENTER AND GO TO THE HOW TO'S AND ITS AT THE TOP.HOPE THIS HELPS AND GOOD LUCK.
Old Mar 17, 2002 | 11:53 PM
Maximum Velocity's Avatar
Before you seal them up, stick them on a cookie sheet in the oven with some dessicant at a low setting...around 110 or so. This should dry out the moisture. Then cool them down and seal them up with silicone.
Old Mar 18, 2002 | 12:04 AM
NoHalo's Avatar
Re: so. what's the answer to water in the clear side markers?
Here are the instructions:
http://www.5thgenmaximas.com/clearinst.html
Definitely a good idea to seal them. I sealed mine..
Old Mar 18, 2002 | 01:00 AM
RBa's Avatar
RBa
Re: Re: so. what's the answer to water in the clear side markers?
Hey roger..
Once you get water in them.. They never come out.. I've tried everything from the blowdryers to cooking them in the oven... When it finally seemed like the water had disappeared, it would comeback after a trip to the car wash... I'm just going to go and buy me a new set since it's only about $50..
If you want.. You can steal toylet's.. SHHHHHHHHHHHH.... LoL!!!!
Old Mar 18, 2002 | 06:38 AM
TPI Monte SS's Avatar
Re: yeah def silicone
Roger
Roger, I'm with ya. I used the amber bulbs that came with my fronts, and installed PolarG red 194s in the rear. At night, they actually look red, not pink like some of the others I've seen. I'm glad I bought them, don't wanna give the a reason to pull me over.
Old Mar 18, 2002 | 07:08 AM
Re: Re: Re: so. what's the answer to water in the clear side markers?
Originally posted by RBa
Hey roger..
When you cooked them in the oven, did you put dessicant in a little bowl with them? The dessicant should absorb the moisture that is present in the sidemarkers. Hmm, it should work.
Old Mar 18, 2002 | 07:39 AM
TellschMax02's Avatar
I have to agree with this method. I had some condensation in my driver’s side front clear marker. I took it out and put it in the oven for about an hour...all condensation was gone. When I first put the clears in, I put a little silicon on them...that was the mistake. Put a lot of silicon on it. Use your finger and mash it all throughout the place where the lens meets the plastic fitting.
I have no more problems...except the dam pink lights!! I need to find a good RED bulb.
Brian
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
boomerbrian
Sep 4, 2015 08:25 AM
