Tail Lights Question
Old Mar 20, 2002 | 10:17 AM
themannix
Does anyon eknow if the 2001 Maxima Tails can be switched out with the 2002? I know the 2002's are clear and the 2001's are black tinted, but are they the same size? Let eme know. Thanks.
Old Mar 20, 2002 | 10:19 AM
djmaxski's Avatar
I think they are.
Old Mar 20, 2002 | 10:26 AM
2Maxed-out4u's Avatar
Yes they can, cause I did it. IT's really simple. Pop old tail lights out and place those in there. took me an hour. But that was the first mod I did to car, so I was kinda nervous and scared of screwing up.
Old Mar 20, 2002 | 10:32 AM
MaxSEima's Avatar
Hey 2Maxed-out4u can you post a couple of pics of your car...i'd really like to see how your chrome fenders look like.
Old Mar 20, 2002 | 10:40 AM
krazyd's Avatar
Re: Tail Lights Question
They are exactly the same size, and look good on most Maximas. You can buy them from either Courtesy Nissan or CustomMaxima. Post pics if and when you decide to get them! The install isn't that difficult once you get out your old taillights.
Old Mar 20, 2002 | 10:41 AM
PCGuRu2K's Avatar
It was probably the 3rd mod I did to my car. Fairly simple. It was just a B!tch to remove the tails cuz it had all that sticky tar sealant thing.. Took some nice tugs and pulls..
Old Mar 20, 2002 | 10:43 AM
krazyd's Avatar
Could you post some pictures of your car with the 2k2 taillights installed? I might be interested in getting them sometime soon for my 2k1 Super Black Max.
Old Mar 20, 2002 | 10:45 AM
themannix
Thanks for the info-
Next, I said 2001, is 2001 and 2000 same rear black tails? And will both fit in 2002? Sorry, I shoulda clarified. Also- any pics of a 2k2 with 2k or 2k1 tails swapped in? Sen me link or post please.
Old Mar 20, 2002 | 11:01 AM
themannix
I'm an idiot-
The more I read most post, the more vague i sound to myself. Bottom line, getting a 2002 max. Dont like the clear tails. I like the Black-Glass tails on 2000 and 2001 (they're same right). I want to put 2k or 2k1 into a new 2002. Everyone's saying that it is possible right? Thanks- sorry I'm an idiot.
Old Mar 20, 2002 | 11:12 AM
krazyd's Avatar
Re: I'm an idiot-
Calm down dood This is possible. First off, the 'black-glass' taillights are called Smoked-Carbon Tails (I think), and they're from any 5th Generation SE model Maxima. Secondly, they would fit your 2k2 Maxima. You could get those from DaveB. I don't remember his # though. Do a search and you'll get it.
Old Mar 20, 2002 | 11:22 AM
Greg's2kGLE's Avatar
Yes, they are direct replacements. A hit of advice when taking your old tail lights off...heat up the outter edges of the lights with a hair dryer to loosen the sealant. It will make it much easier to take them off. Hope that helps
Old Mar 20, 2002 | 11:35 AM
krazyd's Avatar
Greg, is it easy to put the lights back in after you take them out? Like say I wanted to take out my stock lights, and then put them back in, is that difficult to do? Or is it just as easy as putting in a different set of lights?
Old Mar 20, 2002 | 11:39 AM
It's real easy. Just take out the 4 or 5 button things that hold the carpet in, pull that away, disconnect the wiring harnesses, take out the 4 (I think there's 4) bolts (I think you need a little socket wrench for them), heat up the edges and pull the lights out the back. Then scrap off the old sealant (or use new sealant if your lights come with it), heat that up a little and put it around the edges of the new lights. SLide them back in and put back the bolts.
Old Mar 20, 2002 | 11:42 AM
themannix
(Deeeeep Breaaaths)
Ok- I'm aight now. Thanks KrazyD. I think those 2k and 2k1 lights are so much better then the 2k2 tails. That would be my first mod. I'm thinkin of gettin a GLE. I wonder if anyone would switch me thier 2k or 2k1 tails for my 2k2 tails? Good chance you think? Anyon eever here anyone talkin bout it? holla
Old Mar 20, 2002 | 11:46 AM
krazyd's Avatar
Re: (Deeeeep Breaaaths)
It depends on what color your car is going to be? If it's a Super Black Maxima, like mine, then the Carbon tails will look great because they match the paint job. The clears look great on White/Grey colored cars though...
Old Mar 20, 2002 | 11:59 AM
themannix
Re: Re: (Deeeeep Breaaaths)
I agree man- I'm getting Super Black 2k2. Thats why i want the black/carbon tails. They'll look hot I think.
Old Mar 20, 2002 | 12:11 PM
Newman's Avatar
Re: Re: Re: (Deeeeep Breaaaths)
instead of buying new tail lights for $150+ but spend the $50 or so
to get your tail lights painted body color like Greg did (see his sig) although, your bottom half of the light will be amber, not clear like greg's since he has 2000 lights and they are different than the 2002s in that respect.
vingodine
45
May 21, 2016 12:46 PM
tommy20020
Jan 6, 2016 04:05 PM
4doorGTR
Sep 11, 2015 04:09 PM
Sir Tilus
Aug 30, 2015 08:33 PM
220k+ A32
Aug 17, 2015 03:57 PM
