AE pedal installation?
Old Mar 27, 2002 | 05:07 PM
LouE37's Avatar
First of all I would like to thank all the forum members for helping me get started with my Max. I was wondering how exactly to install the AE gas pedal lever to my 2000 GXE. Is it hard...is it easy. Any input would be appreciated...thanks!
Old Mar 27, 2002 | 07:56 PM
maxman00's Avatar
Its not too difficult
Here you go. Sorry for not explaining in greater detail. If you have any questions let me know.
-Unbolt the accelerator (two bolts), I found the use of an angle attachment for the ratchet helpful.
-Disconnect the throttle linkage (located next to the TB) this will give you the room needed to pull the pedal down and disconnect it from the throttle wire. Disconnecting the linkage is similar to disconnecting a V-brake on a mountain bike.
-Disconnect the pedal from the throttle wire
This is what worked best for me. I found it next to impossible to disconnect the pedal with out disconnecting the linkage first.
Old Mar 27, 2002 | 08:20 PM
LeftCoast's Avatar
I disconnected the accelerator pedal by popping the plastic piece on the upper backside of the petal towards the engine (used a philips screwdriver). You can get the idea by looking at the the accelerator pedal on the AE assembly. I simply snapped the pedal back on without removing the original assembly. Worked like a charm....
-Left
Old Mar 27, 2002 | 09:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I threw it in the "How-To" sticky
Click here:
http://forums.maxima.org/showthread....3&pagenumber=4
Towards the bottom.
Old Mar 28, 2002 | 03:11 AM
LouE37's Avatar
Well this was my first post and let me tell you...maxima.org is awesome...thanks again guys for your help and keep those Maximas kickin' ***!!
Old Mar 28, 2002 | 07:10 AM
whitam
Speaking of drilled pedals, has anyone found one for the "dead" pedal left of the clutch? Thanks...
Old Mar 28, 2002 | 08:28 AM
IceY2K1's Avatar
Not matching.
I was hoping the HLSD 2K2 or maybe the 2K3 will have one I can "steal".
Let me know if you find one.
Old Mar 28, 2002 | 08:56 AM
maxman00's Avatar
that would be nice if Nissan made one! Especially for us frost interior guys.
MaxLife17
Jun 27, 2019 01:37 PM
ef9
Sep 10, 2015 10:35 PM
jcvgn
Sep 10, 2015 08:03 PM
slowlifer
Sep 8, 2015 05:53 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
