Slow acceleration after 60 ???
Today on the freeway i floored my Max as i was cruising at 60mph, i noticed tat the acceleration after 60 was slow and the rpm didnt even go above 3.5 even though i floored it, does anyone know why ? Can some1 explain
? Thanxs
? Thanxs
well...
if you slowly go WOT, it will not down shift, hence RPM will not climb.. but if you punch it, it should shift and RPM will go up. RPM is not equal to WOT. if you need to find out if you have a problem opening the throttle, then you should look at the throttle position sensor. It can be checked with a OBD2 reader/scan tool, maybe even a voltage meter directly.
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
