lowering with 19" rims
If I was to get 19" rims could I still lower my car with the H&R + KYB setup with no rubbing or fittment issues tires are 235/40/19 kuhmo please give thoughts and experiences if anybosy has them.
Well....
two things to consider:
1. From sample tires I have checked the specs on, you will be adding at least one full inch to the overall diameter from the stock size...not good if you are lowering and already limiting your wheel well clearance and turning clearance...
and...
2. Will look pretty ghetto...
and...
I'd suggest lowering before putting any larger rims on a car.... it looks horrible with huge wheel gap with big rims. But anyway about those, as long as you keep pretty much the same overall diameter as the origioal specs, then you won't have any fitment problems. I have heard that 245s sometimes rub in the back if there's a lot of weight back there, but that is only hearsay.
Check out this link to double check that your new rims + tires will have the same diameter as stock.
http://www.miata.net/garage/tirecalc.html
yes, you can lower your car with 19" wheels. Now as for your 235/40's ... that's another story. The H&R combo you are talking about is not as low as the Progress that I have and I am running 245/35 series tires. I have yet to rub. I have my stereo in the back as well, but like I said (knock on wood) I have not rubbed once.
My suggestion is get your 19" wheels, get your H&R's, but change your tire size to 235/35 or 245/35. Either of those should be fine with no rubbing. Why are you set on getting 235/40 series tires. If it is price ... look at other manufacturers.
Originally posted by TRUblu2K2
any other thoughts that didn't help much. whatever ghetto Ok buddy the rims are 19" axis muse
As far as 19's being Ghetto .. What kind or garbage is that ? I guess all those people in S Class Benzes with 19's and 20's at the country club are a bunch of Ghetto freaks then ?.. That was not a smart remark.....I have seen LIGHTWEIGHT 19's..not sure how much they cost...
Yeah they are called oz superleggeras, ro_ja formula 5's and 7's. Price is approx 500-550 usd per rim. Superleggeras are 21 lbs each and ro_ja's are 22-25 each.
a 235 or 245 40 will fit and ride ok. Make sure you get an offset that will push the wheel out more, (around 40mm). You could also go 255-35 that will give you more width for handling and more sidewall for some soakup. It may rub a tad on big bumps. For safty of no rubbing 245-35 with a 40mm and the drop will be easy. And if rubing is an issue at any point just trim the fender inside a bit.
Re: lowering with 19" rims
Hey, no matter the cost, or neighborhood...
Hey, 'smart' guy...as stated above, he wanted input...not you getting all defensive because someone has an opinion...
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
