The Light Around The Ignition Key
Old Apr 5, 2002 | 08:56 AM
studman's Avatar
I know it was posted somewhere, but can someone tell me how (and if) I can change the green light that surrounds my ignition key to a blue one. I searched the forums, but didn't find it in the results.
Old Apr 5, 2002 | 03:18 PM
myktek's Avatar
it's just a green led...if u take the whole console off..that this just comes right off....have fun..
Old Apr 5, 2002 | 05:43 PM
JBWhitley's Avatar
Re: The Light Around The Ignition Key
If you do this, let me know how hard it was and how it looked. Please.
Old May 1, 2002 | 08:48 PM
studman's Avatar
Well, I did it. It's the same #37 wedge bulb that are in the dash, which means that they don't come in colors :-(. << Frown with a zit. LOL. The good thing is that the "green" color is made by a cap on the bulb, so you have the option of taking it off and making the ring white. I went a little further as to try to get the bulb to the color blue that I am using, and was unsuccesful in doing so (as I was in the dash lights too). If anything changes, I will reply to this post.
Old May 1, 2002 | 09:21 PM
emax02's Avatar
I thought radio shack sold those little bulbs in blue? I'm going to have to check that out, I was thinking about doing this today too
Old May 1, 2002 | 09:34 PM
MaximaZero's Avatar
Needs non-Maxima Friends
color the bulb with a sharpie!
Old May 1, 2002 | 10:13 PM
emax02's Avatar
Whats a sharpie?
Old May 1, 2002 | 10:32 PM
MaximaZero's Avatar
Whats a sharpie?
a sharpie? as in felt tipped permanant marker?
Old May 6, 2002 | 09:11 PM
emax02's Avatar
I pulled the little bulb around the wheel out on Saturday. I took the green condom off of it and I painted the bulb blue. Now it looks like a super white bulb but it's a little dim. I looked around a bit for a colored bulb in this size but I had no luck.
Old May 7, 2002 | 12:14 AM
DrVolkl's Avatar
How hard was it to get at the bulb in the first place? How many screws, etc etc..
Old May 7, 2002 | 06:22 AM
studman's Avatar
3 screws for the steering wheel housing. Then just slowly pull them apart. Once it's off (it may take a bit to remove it), then you can just twist the bulb to get to it.
Old May 7, 2002 | 08:05 AM
THEKNITE's Avatar
Just put a blue condom on..
As far as i remember my performance shop had all sorts of those small and big colored bulb condoms. But than again, i'm not sure what bulb are we talking about. Actually the green "ring" light matches my cheap door step lights.
Good luck
Old May 7, 2002 | 08:08 AM
jjs's Avatar
jjs
Just a thought...
but sine that light does not stay on very long, why not try some hobby shop (craft store) glass staining paint/dye...I have not actually looked, but some may be heat resistant..
Old May 7, 2002 | 08:21 AM
THEKNITE's Avatar
Re: Just a thought...
Wouldn't that dim the light a lot?
Old May 7, 2002 | 08:23 AM
emax02's Avatar
Theres was 4 screws on mine
I got the bulb out in less then 5 minutes of work with no instructions. It's pretty easy to do.
Old May 7, 2002 | 08:24 AM
jjs's Avatar
jjs
Re: Re: Just a thought...
Would that really matter? I mean it is more of an accent thing anyway once you get used to where your key goes...
Old May 7, 2002 | 08:28 AM
Magellan's Avatar
I can just picture studman getting his car ready to sell someday. He takes off all the mods so a buyer won't suspect the car has been altered. A prospective buyer checks out the car. "Umm, looks pretty good, everything stock, probably driven conservatively. Let's start it up. Wait, what's this? The ignition light is blue. Forget it, this car is a post-moded fraud."
Old May 7, 2002 | 08:45 AM
kpark's Avatar
I attempted to change the bulb color a while back. It's not just a plug in play mod. The bulb doesn't plug into a socket or anything. It's hard wired into the steering column somewhere. I ended up frying my smart enterance control module. Lucky a dealer replaced it under warranty. I told them I had no idea how it happened
Old May 7, 2002 | 08:51 AM
emax02's Avatar
Not true, the bulb does come out of the socket, it is a plug in. I had to use my teeth to pull it out but it does indeed come out
Old May 7, 2002 | 12:25 PM
JBWhitley's Avatar
Ok, Some of us screwed up b/c I had to take 5 out of my steering column. 2 hold the top to the bottom and the other 3 hold the bottom to the wheel.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
