Injen
Old Apr 7, 2002 | 12:07 PM
Bulldawg's Avatar
Injen
Has anyone heard any news about the Injen CAI?
I remember seeing a post that coming out soon, but I haven't heard anymore about it. Somebody correct me if I am wrong, but the Injen CAI doesn't require cutting a hole in the fender.
Old Apr 7, 2002 | 12:23 PM
MyownNismo's Avatar
Future Camaro SS owner
Re: Injen
I posted it when I called them and they said they where making one. Just my luck when I bought the PRCAI it had to come out. Oh well doesn't matter to me.
Old Apr 7, 2002 | 01:54 PM
NuJerseyDrive's Avatar
My roomie with the Alty 2k2 is getting his this week. It looks like a good intake. I'll let you know.
Old Apr 7, 2002 | 04:58 PM
KLOOGY's Avatar
L33t BMW Drivah
Injen intakes " LOOK " great, im not sure as to how good they are. Im not sure how you could make a CAI for the Max without CUTTING ?
Old Apr 7, 2002 | 05:34 PM
Bulldawg's Avatar
Well if you look to the left of your battery and to the right of your engine, it looks like you could run something down there?
just an idea
Old Apr 7, 2002 | 05:59 PM
y2kse's Avatar
A front-mounted CAI for the 5th Gen Maxima that did not require cutting was made at one time. The filter was a panel type that mounted in front of the radiator and was protected by a piece of Plexiglas. The problem is that installation of the CAI required removing the driver's side fog light. As a result, no one that I'm aware of ever purchased one of these CAIs.
I don't know if enough room exists in a 2K2 to install a front-mounted CAI without removing the driver's side fog light. I'm also unable to find the web site of the manufacturer of the front-mounted CAI. They may be out of business. But the idea may give the inventive among you something to tinker with.
Old Apr 7, 2002 | 06:42 PM
ssiperko's Avatar
After lying on back for about 20mins and prodding around I don't see a easy no-drill/cut method. The only easy way would be to maybe cut a hole in the lower splash shield and "pipe" air up through past the trans. (once the core support mounted intake is removed) to the intake setup.
I say mount a small scoop right above that sucker (air intake) and get the cooler air "forced" in. To balance the look add another scoop to the pass. side. You could add a drain and filler for wet conditions. My thoughts.
Thanks -- SS
Old Apr 8, 2002 | 10:21 PM
KLOOGY's Avatar
L33t BMW Drivah
AH HAA ! This is a great Idea. If someone can make a RAM AIR HOOD ! , not some ricey thing, maybe like a single scoop hood that leads into a collector and feeds into a custom intake.. This wood work better than some pipe digging into the asphalt ... As I smoke my tires to race a WRX, That air isnt much cooler down there ! .... This is an idea used on Mustangs by CERVINI and on LT1's...
Old Apr 9, 2002 | 12:44 AM
MyownNismo's Avatar
A carbon fiber ram air hood.
Old Apr 9, 2002 | 06:51 AM
timby01's Avatar
i'm waiting to hear back from injen on when the production is going to be complete i'm also trying to get some pics and dyno info from them also trying to start a group deal on these intakes
Old Apr 9, 2002 | 09:22 AM
Bulldawg's Avatar
COOL LET ME KNOW WHEN YOU HEAR SOMETHING
Old Apr 9, 2002 | 09:25 AM
timby01's Avatar
just talked to injen intakes will be out next week and i have to call back in like 2 hrs to get the dyno results will keep u posted
Old Apr 9, 2002 | 11:20 AM
HulaMAX's Avatar
Sounds great! Keep us posted!
Old Apr 9, 2002 | 02:08 PM
timby01's Avatar
ok just got off the phone with injen and they said it dynoed 16hp to the wheels of a 2002 manual
Old Apr 9, 2002 | 02:28 PM
2002 Max SE's Avatar
I look forward to seeing dyno and price - keep us posted on a group deal. 16 HP, no cutting, and reasonabley priced - sounds promising. Does anyone know if Place Racing CAI can be used on a 2002 or is Injen going to be the sole CAI available? Thanks again!
Old Apr 9, 2002 | 03:41 PM
y2kse's Avatar
Has anyone actually verified that the Injen CAI doesn't require cutting the fender?
Place Racing does make a CAI for the 2K2.
Old Apr 9, 2002 | 03:49 PM
timby01's Avatar
they had told me that it requires no drilling or cutting but i sent an email just to verify it 100%
Old Apr 9, 2002 | 03:53 PM
y2kse's Avatar
That's terrific news if it's true. Could you check and see if they plan to make a CAI for the 2K/2K1 Maxima? Thanks.
Old Apr 9, 2002 | 04:40 PM
HulaMAX's Avatar
timby01, I'm just curious...who are you dealing with on this GD at Injen? I used to know someone at Injen...
Old Apr 9, 2002 | 04:48 PM
timby01's Avatar
i'm dealing with a dealer out here in NY i talked to the people @ injen and i could not do a group deal through them
Old Apr 9, 2002 | 09:25 PM
KLOOGY's Avatar
L33t BMW Drivah
I think the Injen Intakes look awesome .. But I doubt those Dyno numbers.. I have never seen a CAI produce more than 5-10 HP ..... I would love to see them back this up ! If it is indeed true. I will cough up my Frankencar....I also want to see the price !
Old Oct 6, 2002 | 09:10 AM
Morpheus's Avatar
Yep, no drilling needed with the injen cai, isnt that spiffy?
Old Oct 6, 2002 | 09:30 AM
DrVolkl's Avatar
No cutting..at least I didn't cut anything. It's a great mod, but I think I'm going to have to wrap it in some header tape because the engine on the 3.5 gets so damn hot.
Dasmith
Aug 25, 2015 10:15 PM
GregP
Jul 28, 2002 09:20 PM
PCGuRu2K
Jul 19, 2002 09:47 PM
MichaelAE
Jul 6, 2002 07:43 AM
