Installed H&Rs over weekend
Old Apr 8, 2002 | 12:39 PM
kpark's Avatar
The handling has improved a lot! I can't believe the difference. The guy who did the install said my rear left shock is bad and leaking oil. I can't believe one my shocks died even before I lowered my car! He even charged me an extra $40 after the install because he said he had a hard time with the rears. I was planning to get my shocks done by him too. Anyways, what are my aftermarket choices? Tokicos seem to give many people problems, Koni's need modification, what KYB solutions are available besides the adjustables since they're not out yet?
Old Apr 8, 2002 | 12:49 PM
noflash's Avatar
Re: Installed H&Rs over weekend
Cattman's freakin expensive modified or some used SE's.
Old Apr 8, 2002 | 05:53 PM
Greg's2kGLE's Avatar
Re: Re: Installed H&Rs over weekend
Why would you put used SE struts on with lowering springs?
kpark, how many miles do you have on your car? Tokicos are popular, KYBs are adjustable/expensive/moddified by Cattman to fit (only available this way from Cattman) and Konis have to be modified a little to fit. So right now Tokico's are your only option for easy fitment and less money.
Old Apr 8, 2002 | 06:05 PM
zman187's Avatar
You really shouldn't use stock struts. Plus I have the tokico's with progress springs and haven't had any trouble plus many people like the tokico's
Old Apr 8, 2002 | 09:11 PM
Dany's Avatar
How is the ride with H&Rs? I am getting them done soon. I am gona be installing them on stock shocks too.
I don't think there are any good shocks available for Maxima. Plus stock shocks are already made by Tokico.
I used to have Tokicos blue on my 95 Maxima with H&Rs and those shocks sucked.
How many miles do you have on your Maxima? It is strange that your shocks is leaking. My friend has a 96 Maxima SE with over 100K miles on it and his original shocks are as good as new.
Old Apr 8, 2002 | 11:00 PM
KLOOGY's Avatar
L33t BMW Drivah
Im going Maxspeed because a Tech told me the stock suspension is awesome.. Im just looking to go an Inch lower ...
Old Apr 9, 2002 | 07:03 AM
Galo's Avatar
Maxima Pilot
Konis dont need modifications for rears
they are a direct bolt-on fit.
For the fronts, you either modify the Konis or purchase the older Gen4 upper shock tower mounting point and then they too will be a direct bolt-on fit -but as in all Konis, you do have to modify the strut itself because the Konis are a inner cartridge-type shock, meaning they fit inside the strut after you've cut away the top of the strut and emptied out all the innards.
Old Apr 9, 2002 | 07:48 AM
THEKNITE's Avatar
Originally posted by kpark
The handling has improved a lot! I can't believe the difference. He even charged me an extra $40 after the install because he said he had a hard time with the rears. I was planning to get my shocks done by him too.
How much did the H&Rs cost ya, and how much for install? My car still sways with RSB so thinking about H&Rs.
thnx
Old Apr 9, 2002 | 08:46 AM
kpark's Avatar
The ride with H&Rs are great. Very stable and firm. Some may think that the ride is rougher, which is a given if you lower your car at all, but it's not that noticable compared to stock. I have 30k miles right now. The answer Greg's question.... I know, I know you should do springs and shocks at the same time. It was a money issue and wanted to use the stocks until they blew. Of course I wouldn't have done this if I knew one of them blew already. The guy who did my install had such a hard time with my car he's hesitant to do my shocks now, either that or he wants to charge me a lot more.
Old Apr 9, 2002 | 09:46 AM
maxman00's Avatar
when you say, a tech told you the stock suspension is awsone, does this mean you are going to install maxspeed with stock struts?
MaxLife17
Jun 27, 2019 01:37 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Vequity
Sep 10, 2015 05:26 AM
MaxLife17
Sep 8, 2015 02:36 PM
