Intakes?
Old Apr 17, 2002 | 09:44 AM
  #41
y2kse's Avatar
Originally posted by dmbmaxima88
place racing uses them, weapon R does and so does HKS.
Pass on the HKS. It's a POS! And you forgot Amsoil.
Old Apr 17, 2002 | 12:56 PM
  #42
acMAX's Avatar
dude......
Franken Intake all the way!!
You won't regret it......
Old Apr 18, 2002 | 01:08 AM
  #43
BippuBenji's Avatar
Really? Why is it a POS?
Old Apr 18, 2002 | 04:46 AM
  #44
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Originally posted by Lumbee799
Midpipe looks like an extension piece. Is this correct Steve?
it replaces the stock accordian resonator thingie and provides better looks, smoother airflow, and better sound.
-steve
Old Apr 18, 2002 | 07:52 AM
  #45
y2kse's Avatar
In a recent test of the most popular aftermarket air filters, the HKS came in dead last in terms of filtration. It seems that the best filter element is paper (OEM, A'pexi) and the worst is non-oiled foam (HKS).
If you do a search, you can find a link to the test results. I believe they were posted in one of the "Frankencar" threads.
Old Apr 18, 2002 | 08:31 AM
  #46
BippuBenji's Avatar
Ahh, thanks for the info, I was just about to use an HKS filter for my CAI install, but now I think I'm gonna either get a real K&N or the Apexi filter. Does that apply to all non-oiled filters, such as the Dragon filters? And what about those Monsterflow filters?
Old Apr 18, 2002 | 09:34 AM
  #47
y2kse's Avatar
I would not use a non-oiled foam filter under any circumstances.
The MonsterFlow filter uses a "tackifier", which I suspect is their fancy-dancy name for "oil". So it's probably OK. But I'd suggest you stay away from it until it's been tested by an independent lab or an oil analysis has been conducted by Blackstone Labs on an engine with a MonsterFlow installed.
The A'pexi filter is excellent both in terms of air flow and filtering capability. But it's expensive to replace. As with any paper filter, the entire filter needs to be changed following each duty cycle. And the cheapest price I've seen for the replacement filters is $60.00.
K&N is always a good choice. It has about the best tradeoff between filtration and air flow. And it can be cleaned and re-used, of course. But I don't do that. For the price of a new filter and the peace of mind that comes with it, I purchase a new filter at the end of each duty cycle. K&N replacement filters run around $30.00 to $40.00 unless, of course, they have someone's name other than their own on the end cap.
Old Apr 18, 2002 | 09:39 AM
  #48
00MaxSE's Avatar
Pointy Elbows
Berk Intake
Originally posted by Maximam
Franken has been a popular one, it contains a mid-pipe which is very much needed. The BERK intake is the best for the $!!!
Mark
The Berk Tuning intake is definately the best for your money. I got mine on ebay for $50! But I needed to make a bracket and put another cable tie around the intake to stop if from bouncing around. Also that black bracket that held the factory air box needed to be taken out. Did you have the same problems Maximam?
Jason
Old Apr 18, 2002 | 10:29 AM
  #49
Maximam's Avatar
Re: Berk Intake
Jason
I bought mine new for $59. Yes I tied up the cold air intake to deliver some air to the filter. I also just left the black bracket for now. The mounting bracket came with it and holds it very secure.
Mark
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
