ATTN: Don't buy the trust strut bar.
Old Apr 13, 2002 | 02:40 PM
MyownNismo's Avatar
Future Camaro SS owner
I was going to install my strut bar that I got off of e-bay. But when I went to install the bolts that hold the rings to the bar seezed and needed and impact gun to break them off. So I had to buy new bolts. If I knew it was going to be a piece of S**t I wouldn't of bought it.
Old Apr 13, 2002 | 02:54 PM
see5's Avatar
Maybe I missed something?
The bolts that broke were the ones that hold the plate down?
Impact wrench?
Should be torque wrench. Did you break the Nissan bolts?
Old Apr 13, 2002 | 03:00 PM
NuJerseyDrive's Avatar
I got that bar. No problems here
Old Apr 13, 2002 | 03:06 PM
MyownNismo's Avatar
Impact wrench?
No this one that holds the bar to the plate.
Old Apr 13, 2002 | 03:31 PM
acMAX's Avatar
i did the same thing with my courtesy strut bar......I
didn't thread the bolt properly and it ended up snapping.
I'm thinking that's what you did too.....
It's not like the bolts make a difference anyway.
I ended up buying some new bolts that were the same size.
Old Apr 13, 2002 | 05:45 PM
MyownNismo's Avatar
Does yours touch your hood I don't know if mine does but if you look directly from the side eye level with the top of your fender does yours stick up higher then the fenders.
Old Apr 13, 2002 | 06:48 PM
e28fixer's Avatar
Did the same thing with one of my bolts...
...that came with the Trust bar. Went to Lowe's to buy a nice pair of stainless bolts & nuts so I'd have a matching set. While installing the first of the new bolts I (again) apparently managed to cross-thread a nut and ended up breaking one of the new bolts. Now I have a nice un-matched set of bolts holding the bar. Oh well. I'm dubious of the bar's effect on handling anyway.
Scott Buchanan
2K SE (manual)
Old Apr 13, 2002 | 07:06 PM
MyownNismo's Avatar
Re: Did the same thing with one of my bolts...
Scott Buchanan
2K SE (manual)
I have carbon steel bolts from work can't strip or cross-thread. does yours touch your hood.
Old Apr 13, 2002 | 07:20 PM
e28fixer's Avatar
No touching of the hood that I'm aware of...
Install was very easy and hood closed without any contact. I was pleased to get the bar for around $65. This was before all the group deals for similar bars at an even lower price. Like I said, I have doubts of it's effects on handling, but I had one in my BMW so why not in the Max? BMW was an '87 though, so I'm certain chassis stiffness has improved since then.
Scott Buchanan
2K SE (manual)
Old Apr 13, 2002 | 07:44 PM
jkratzer's Avatar
I've got that bar also. No problems with the bolts and it does not touch the hood( the hood closes just as easy with the bar on or off ). Sounds like a user error instead of a bad bar.
Old Apr 13, 2002 | 09:03 PM
MyownNismo's Avatar
The problem with it being user error is that I got today and tried to install and the bolts did not move and had to take it to a shop were they put it in a vise and used and impact and the busted. I could even use a wrench and a allen wrench to move it. Thanks for the info on that it doesn't touch the hood and fixed the problem by using carbon steel nuts and bolts.
Old Apr 13, 2002 | 09:20 PM
zeitgeist57's Avatar
I got the COURTESY FSTB and snapped off BOTH bolts when taking the bar off for spring install...I just happily got some good Grade 8 bolts from the autostore for replacements. I'm almost GLAD that the weaker chrome bolts were gone so I could get excellent quality hardware.
Old Apr 13, 2002 | 09:51 PM
MyownNismo's Avatar
I am think of making the bar out of a different metal (not saying that the bar I bought sucks it's just that I found out I can make the bar at work out of a stronger material. After buying it and looking at it I could make it all at work on a mill.
Old Apr 13, 2002 | 09:55 PM
acMAX's Avatar
I definitely agree with you there.
Those bolts were garbarge...
Old Apr 14, 2002 | 04:15 AM
JJL's Avatar
JJL
I had the same problem with the bolts,something is wrong with them.
The bar is so close to the hood that it was blocking the windshield washer hose ,liquid would not flow on left side.I had to reroute the hose.
Other then that that bar is a must have,it should be redesigned through for better clearance
I have this bar
http://www.courtesyparts.com/secondtier_a33.html
Old Apr 14, 2002 | 06:08 AM
big h's Avatar
i've ordered this bar also. can anyone give me the type(size) of bolt they had to buy. What are good grade 8 bolts?
Old Apr 14, 2002 | 09:14 PM
radpp16's Avatar
Re: ATTN: Don't buy the trust strut bar.
Anyone know who sells cheap RSTB(no not the RSB).
Roger
Old Apr 14, 2002 | 09:33 PM
KLOOGY's Avatar
L33t BMW Drivah
This thread is why I have yet to buy one.. all these people selling CHEAP FSTB are selling them cheap for a reason. I guess Stillen is justified for selling theirs for 200.00 ! Has anyone had problems installing that ?? If so let me know !
Old Apr 14, 2002 | 10:12 PM
MyownNismo's Avatar
That's why I am making one at work.
Old Apr 15, 2002 | 07:12 AM
got rice?'s Avatar
FYi, Trust/GReddy does not make a STB for the Maxima. The person on Ebay is deceiving people on this. If it was a Trust bar, the bracket is silver, not red. You're getting the Top Speed/Courtesy Bar
Old Apr 16, 2002 | 01:38 AM
MyownNismo's Avatar
My brackets are black.
Old Apr 16, 2002 | 06:25 AM
got rice?'s Avatar
http://www.eatricezone.com/miata/sus...eddyfstb07.jpg
GReddy brackets are silver
Old Apr 16, 2002 | 11:25 AM
MyownNismo's Avatar
They are also black but not saying mine is a Trust/Greddy.
95Maxi
35
Sep 2, 2015 10:37 AM
seesole
Aug 26, 2015 11:22 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
