HIDs what do i need?
ok i want to put HIDs in my 2000 max. what do i need to buy/do in order to get the going? i have seen a few kits for sale but will the HIDs fit right inot the factory H4 area? are tehy going to be too hot for the headlight fixture? am i going to need to splice/cut wires? will i loose my High beams? do i need to alter the factory headlamp so not to blind other drivers? i need help
if anyone feels like helping me out, i thank you. i guess i need prices and instuction.
-Sean
if anyone feels like helping me out, i thank you. i guess i need prices and instuction.-Sean
hope this helps
a friend of mine who owns a 2000 max had one installed about few months ago. he made a patch cord btwn the 2000 harness and oem HID lamps.
you need:
2x 2k2 mounting clips
2x oem hid lamps
2x 2k2 hid connectors
2x 2k2 highbeam connectors
2x 2k H4 connectors
2x 2k side signal lamp sockets
some wiring lomb
follow one of the 2k2 write-ups and you should be fine...
it should look something like this:
<p><img border="0" src="http://66.125.192.138/cable.jpg" width="400" height="300"></p>
you need:
2x oem hid lamps
2x 2k H4 connectors
some wiring lomb
Re: hope this helps
Originally posted by maxkillz74
[B]a friend of mine who owns a 2000 max had one installed about few months ago. he made a patch cord btwn the 2000 harness and oem HID lamps.
you need:
2x oem hid lamps
2x 2k H4 connectors
some wiring lomb
you need:
2x oem hid lamps
2x 2k H4 connectors
some wiring lomb
you also need 2x 2k2 turn signal connectors
all of which you can buy from DaveB
without splicing wires and going with the patch cord:
fogs do turn off when you flash high beams
setting off the alarm does flash the high beams (bad for bulbs)
that's about it. it looks and feels like the 2k2 that i have. you might want to do some aiming since i've noticed that they are aimed a little high from the install than from the factory.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
