5th Gen Angel Eyes...
Old May 21, 2002 | 03:49 PM
spyhunter's Avatar
For those of you that expressed interest in the Angel Eyes project. After some investigation, 5th gen Angel Eyes are possible. Production and test fitting will start sometime this week. However its going to be a lower cost that the e36 headlights. The 5th gen Angel Eye kit will consist off 2 rings with 2 led's a piece that will mount on top of the round fog lights and may even work if for those without stock fogs. We are also investigating into angel eyes inside the headlights for 2k2+ we're just a bit worried about not damaging the hids. more info to come later this week. see the website for details
Old May 21, 2002 | 04:16 PM
[maxi-overdose]'s Avatar
I am sorry...but what does an angel eye lights looks like?
Old May 21, 2002 | 04:18 PM
Padsy's Avatar
Boost.....
CHeck out BMW....
Old May 21, 2002 | 05:13 PM
nevermind...found it...
Old May 21, 2002 | 05:30 PM
lcf's Avatar
lcf
cant wait for pics!
Old May 21, 2002 | 06:30 PM
nissanmaximas's Avatar
Re: 5th Gen Angel Eyes...
Please PM as soon as they are available. put me down for a pair.
Old May 21, 2002 | 06:37 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Re: Re: 5th Gen Angel Eyes...
angel eye gatling gun headlamps... mmmm...
Old May 21, 2002 | 06:56 PM
aznhoopsta03's Avatar
ANGEL EYES
i'm down. just gimme price and a how-2 for install.
Alan
Old May 21, 2002 | 08:48 PM
20th maxstyle's Avatar
I'll send some money now if you need for research.
Old May 22, 2002 | 01:42 AM
Re: Re: Re: 5th Gen Angel Eyes...
angel eye + Q45 HID?
Old May 22, 2002 | 02:50 AM
MiniRX7's Avatar
Are we talking about the 02 headlights hear?? Just the low/high beams??
That would look mega cool!!!
It would give me a good opportunitie to also pop that ugly orange out while the casing is apart.
E-MAX, have you had any problems with condesation or leakding yet??
ED
Old May 22, 2002 | 05:54 AM
warrlocked's Avatar
Does this kit consist of completely new headlamp housings or will we have to take our stock housings apart/install/reassemble?
If we install these in our stock housings will this interfere with the performance of the headlamps?
And the big question....hom much $$$?
Old May 22, 2002 | 06:01 AM
spyhunter's Avatar
the big question and its answers are near. and the answer is, it depends. those that want the headlight angel eyes will have to take them apart and install them or send them to us. those that want the fog light angel eyes the install should be pretty simple and since its half the rings, its half our cost. we well pass on the savings, trust me.
Old May 22, 2002 | 06:07 AM
warrlocked's Avatar
Do these usually interfere with the light pattern or the quality of light from the headlamps?? Will there be any annoying shadows cast on the roadway?
Old May 22, 2002 | 07:33 AM
spyhunter's Avatar
Re: Re: Re: Re: 5th Gen Angel Eyes...
they do not. light passes through it and it does not interfere with the beam pattern.most of the time the rings fit on the outside of or on the outer lip of the lense itself
Old May 22, 2002 | 09:42 AM
Albertt's Avatar
I'm surprised the 5th Gen guys have just come up with this >>
The VW crowd is way ahead of ya:
http://forums.vwvortex.com/zerothread?id=344721
My $0.02...let the BMWs have something they can call their own.
Old May 22, 2002 | 09:46 AM
spyhunter's Avatar
Re: I'm surprised the 5th Gen guys have just come up with this >>
that, along with the ideas from Brandon, is where i got the ideas from. nm
Old May 22, 2002 | 09:55 AM
Albertt's Avatar
Hey, I'll be the first to admit, they look nice >>
but, I wouldn't use LEDs...especially super bright ones. If you look at 5-series BMWs, these aren't that bright...meaning they shouldn't overpower or flood the housing with light. Part of their attractiveness is the well defined circular shape. Excessive light would blur the shape and make it look as though your regular headlamps are dim and blue.
Old May 22, 2002 | 10:04 AM
spyhunter's Avatar
Re: Hey, I'll be the first to admit, they look nice >>
however...have you looked into the prices for the angel eye kits that are the same as the stock 5 series? 350+ for just the rings and lighting. the leds where the cheapested, effective way to go. the 5 series uses fiber optics to light the rings and quite simply are too much money. at 75 bucks our kit works at dusk and at night. the 5 series can be seen dimly during the daytime. is the 200 bucks worth that? with the low beam lights on you can barely see the 5 series rings, and it is the same with our kit. the leds do not flood the housing with light, it merely travels around the rings and does light up the housing from the rings. the only way to control that is with fiber optics.
Old May 24, 2002 | 10:45 PM
2M0A0X2's Avatar
so basically, i can buy these, and install them on my ///M?
Old May 24, 2002 | 10:48 PM
2M0A0X2's Avatar
a lot more cheaper than buying a whole set, and is this a kit to modify my current headlights?
Old May 24, 2002 | 11:53 PM
the paragon's Avatar
Put me down for a pair~
Old May 25, 2002 | 12:01 AM
2M0A0X2's Avatar
but how does this work?
Old May 25, 2002 | 01:22 AM
2M0A0X2's Avatar
cause it would be good if i can get these for my ///m....they cost a lot...
Old May 25, 2002 | 05:31 AM
spyhunter's Avatar
well angel eyes for 5th gen fog lights will be around 45 shipped. the set we currently sell works for all e36 headlights and if i'm not mistaken a 98 m3 is an e36. the rings and leds alone are 80 bucks, quite a bit cheaper than anything available on the market. the euros, german, and JP angel eyes are in the 300-1000 range. the rings are no more than molded plastic with leds mounted at the ends.
Old May 25, 2002 | 09:58 AM
max34's Avatar
Sounds cool.
I'd also like to see some pics before I make a decision.
Old May 25, 2002 | 10:22 AM
warrlocked's Avatar
I am not so sure these would look too good on a 2K-2K1 Max. If you only have ONE of the 'eyes' in the headlamps it would look kinda goofy IMO. Not sure how it would look even if you had them in the fogs and one in the headlights. I will just wait and see what others do and see how it looks.
Old May 25, 2002 | 10:40 AM
lcf's Avatar
lcf
need pics.
Old May 25, 2002 | 12:21 PM
2M0A0X2's Avatar
haha....now, i have a decision to make......whether to tell my fellow bmw friends about this, or let them spend like 200 bucks......
Old May 28, 2002 | 10:41 PM
K Pazzo 6's Avatar
so basically you are selling the rings to put on our current headlights???
Old May 28, 2002 | 10:50 PM
KLOOGY's Avatar
L33t BMW Drivah
If I could ever figure out how to take my headlight apart and put this on, it would look nice, but I'll save my $$ for performance !
Old May 28, 2002 | 11:00 PM
Originally posted by lcf
need pics.
wants pics!
Old May 29, 2002 | 01:56 AM
myktek's Avatar
damn, i'm down for this. . .maybe up to 3 kits. . .hehehe. . .gonna have to do the 2k2 hid's & the fogs.....
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
