5th Gen OEM Brake Info
While researching our factory braking system to see what was the same so I could see what 00-01 aftermarket parts would fit the 2002s I found the following;
Rear Pads/Rotors/Calipers - same part # for 00->02
Front Pads - same part # for 00->02
Front Rotors - (04/99-06/01 same part#) (06/01-02 same part#)
Front Calipers - (04/99-06/01 same part#) (06/01-02 same part#)
This info came from the part #s @ www.nissanwholesaleparts.com
So it seems if your Maxima was built after June 2001 you have the same brakes as the 2002.
I am going to try the following, have new OEM rotors slotted and maybe drilled, 00-01 EBC or something pads, SS lines and Redline Brake Fluid and hopefully this will last at the track and I can avoid buying Stillen's AP kit.
Finkle
09-27-2015 09:53 PM
03VQMAX
09-25-2015 04:19 PM
Cant_Get_Ryte
08-28-2015 06:41 AM
