OMG One More Problem to add
Old May 23, 2002 | 12:20 PM
CIRCO's Avatar
Hey guys I recently swapped out amps for my highs and I am getting some engine noise, but it comes and goes. I sanded the point where I put the ground. I ran power wire on the opposite side from RCA & Speaker wire. So, I take it to a stereo shop and those ****** said that I need new spark plugs and thats the cause of engine noise. WTF!
Old May 23, 2002 | 12:26 PM
2kseman's Avatar
go to radio shack, get a filter(RF filter?), it will block unwanted frequencies coming into amp/speakers.....hope it helps.
Old May 23, 2002 | 12:34 PM
CIRCO's Avatar
What YO! I thought thats a bunch of crap? Doesn't it make the sound coming through a lot softer too?
Old May 23, 2002 | 12:51 PM
Colonel's Avatar
Old Fuddy Duddy
Someone in the GeneralDiscussion noted that making ANOTHER ground help out his issue a lot. EricDwong or something? Read it through...might help ya.
Alternator Whine
Old May 23, 2002 | 01:38 PM
exunaja's Avatar
I have heard from some other shop that completing the ground loop by attaching it back to directly to the -ve side of the battery will resolve that problem.
I have not try that in person but sounds like a legitimate reason.
Old May 23, 2002 | 01:43 PM
asu174's Avatar
Clay Aiken has fancy genitals
These things are complete garbage. They might help eliminate the ground noise a wee bit, but they had more distortion than they are worth. Not to mention the fact that you could potentially pick up MORE engine noise with them.
Are your RCA/signal lines run near the power cord? Separate them if at all possible. I always run the signal up one side of the car and the power and remote turn on up the other side. Then, if you still get noise, find a new ground. Sometimes it just wasn't meant to be.
Old May 23, 2002 | 01:52 PM
asu174's Avatar
Re: OMG One More Problem to add
Oops....sorry didn't see that part. Ummm... yeah. You're screwed.
Old May 24, 2002 | 09:59 AM
2kseman's Avatar
and you know this from? i used it on my RX-7 and it worked fine...unless you've installed one, how would you know? was just trying to assist....pc
Old May 24, 2002 | 10:09 AM
roastduck88's Avatar
Check to make sure you have no exposed wires. If a part of an exposed wire is touching something, you will have engine noise. That happened to my friend.
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
slowlifer
Sep 8, 2015 05:53 AM
