Does anybody have the same performance problem?
Old Jun 11, 2002 | 08:57 AM
Foglght's Avatar
I want to make this as short as possible. When under any throttle right at about 4k rpm, i get a hesitation almost like a missfire. I know the variable intake isn't opening untill at least 5k, so i know its not just a sticking VIAS. Anybody have any coil problems?
Old Jun 11, 2002 | 08:58 AM
melteye's Avatar
I get a hesitation at 4400RPM... I have a 2002.
Old Jun 11, 2002 | 10:42 AM
DrVolkl's Avatar
Yeah, mine too. The altima does the same thing. I think it's the variable valve thingy switching over. I think it's part of the tech of the engine.
Old Jun 11, 2002 | 12:40 PM
20 MAXIMA 02's Avatar
is it exclusively to automatic transmission? because i dont feel any lag
Old Jun 11, 2002 | 01:58 PM
Foglght's Avatar
I have a 5-spd. I have only noticed it since I have gone over 55k miles. it does it more at lower throttle applications. I also have a 2k so a little diff. engine. I also notice it more around 3,800 to 4,500.
and damn.......when its over 90 degrees, this thing feels really slow.
Old Jun 11, 2002 | 02:13 PM
melteye's Avatar
http://forums.maxima.org/showthread....postid=1155056
Old Jun 11, 2002 | 02:32 PM
Foglght's Avatar
I just watched that video, and mine doesn't do that. I will grab my video cam when i get a chance.
show and tell soon
you should definitely get that checked out
Old Jun 11, 2002 | 03:39 PM
Sly's Avatar
Sly
Is yours an early 2K or a late 2K build? The earlier 2K's had defective ignition coils. My 2K's build date is 6/99 and by 48K miles I started to have issues with acceleration and knocking. New coils fixed that problem.
Old Jun 12, 2002 | 07:28 AM
Foglght's Avatar
Mine was built in 4/99. so I must have a really early one. what exactly did it feel like when they went bad. I am a ford guy at a dealership. They apparently react quite a bit different when the coils go bad. And did you get a SES light when they went bad?
Old Jun 12, 2002 | 10:25 AM
[maxi-overdose]'s Avatar
Re: Does anybody have the same performance problem?
just to confirm it is not a VIAS problem....I would do a DIY diagnostic.
Old Jun 12, 2002 | 05:01 PM
Foglght's Avatar
Re: Re: Does anybody have the same performance problem?
I know for sure its not VIAS issues
Old Jun 12, 2002 | 05:42 PM
Sly's Avatar
Sly
The first thing I noticed was that I would get spark knock even when using premium fuel. At first I thought it was a bad Y-pipe because it started happening after I installed one. It would happen more often at part throttle then go away but with a power loss (timing retard?). High RPM would feel very weak, like the power was dropping off. Then I tried changing the plugs, still no difference. Finally after reading enough about other people's experiences here on the .org I decided to change out the coils. Cost me $250 because I got sick of the dealer charging for diagnostics and not finding the problem but at least it's been running smooth ever since. Never got a SES light before or after the swap.
Old Jun 12, 2002 | 06:41 PM
Foglght's Avatar
so how would you describe the difference from before and after. Just so i can get an idea of what to expect when (if) i replace the coils.
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
