A/C blower noise TSB
Old Jun 12, 2002 | 02:53 PM
exunaja's Avatar
I am experiencing this problem with my y2k and looking for a copy of the TSB so I can take it to the dealer without any hassle.
anyone on the board has the TSB the number is 99-071A
thank you in advance
Erwin
Old Jun 12, 2002 | 07:33 PM
mdeal's Avatar
Chances are if you have the TSB number then it will be less of a hassle, or at least speak in terms as if you know there is a known issue in the form of a TSB.
Old Jun 13, 2002 | 06:52 AM
exunaja's Avatar
I will try that .
Thank you
Old Jun 13, 2002 | 07:10 AM
TimW's Avatar
The silent but deadly Moderator
honestly..
I've had this done on the PF and the max. the TSB got me nowhere.. I just had to argue that it was ticking loudly enough to bug me. Even then they acted like it was a favor. On the PF, they didnt argue as much.. but left my door trim hanging down and closed the door on it. brilliant.
both are much quieter now.. those motors are non-servicable and cost like $120
Old Jun 13, 2002 | 08:02 AM
Galo's Avatar
Maxima Pilot
What are the symptoms on this problem?
Old Jun 13, 2002 | 08:08 AM
lcf's Avatar
lcf
Re: What are the symptoms on this problem?
Originally posted by Galo
...ticking loudly enough to bug me.
its a ticking, like a clock. at least in my car, its nothing i cant live with. i forget it even makes this sound most of the time. its BARELY audible... perhaps i am just **** and the ticking from my A/C is not what tim is referring to. my ticking seems to be originating from the right side of the car... the ticking sound speeds up and slows down with the fan of the A/C. it seems that the ticking sound only shows itself when the A/C is on and not in the "vent" or ECON mode.
Old Jun 13, 2002 | 08:15 AM
Galo's Avatar
Maxima Pilot
Hmnnn...interesting. I too have noticed a
ticking sound (nicely loud, BTW) but only when the A/C is turned on for the first time when the car is hot...I was attributing this to hot vents/conduits being subject to the inevitable temperature shock.
After two/three minutes and the temp in the A/C system (conduits, etc) has stabilized the ticking/crackling noises go away completely.
Is this the problem addressed by this TSB? Thanks
Old Jun 13, 2002 | 08:21 AM
TimW's Avatar
the TSB
is to replace the motor and put a insulated cover on it. Its basically the motor bushing making the noise.. its very audible at low speed.
I bought my max because it was quiet inside.. I dont like having to talk over that fan, even tho at its worst, it was quieter than some honda's I've had.
The motor has a cloth pad in there to hold oil for the bushing. the revision of motor I had, all the oil had run out of the cloth and into the shroud. so the motor bushing started going 'shhhck shhhck shhhck shhhck shhhck'
again, its not servicable, so new motor. Its a 15 min job to replace
Old Jun 13, 2002 | 08:26 AM
Galo's Avatar
Maxima Pilot
Thanks. Looks like i'm okay since
mine runs ultra-quiet after the initial ticking...all's well!
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
homewrecker
Sep 24, 2015 07:01 PM
