Fuel Filter
Old Jun 17, 2002 | 07:17 PM
Menasor's Avatar
Fuel Filter
I have heard that the fuel filter in the 5th gen maximas does not need maintanence or something like that. I question that so I was wondering when the best time to replace it would be? Have any of you replaced the fuel filter on your own? Was it hard to get to? I know it's attached to the fuel pump thus I had to ask. If any one can provide any info, please post. Thanks.
Old Jun 17, 2002 | 09:08 PM
ajahearn's Avatar
02 ESM
Says the filter is a maintenance-free item. However it also says that replacement is covered under FE (fuel/exhaust). Basically you release fuel pressure in the line, remove your back seat (provides access to inspection hole), remove fuel pump which contains the filter, take the pump apart and get the filter. Lot of work which is probably why they suggest using premium fluid.
Old Jun 22, 2002 | 04:12 PM
Neal728's Avatar
Has anyone with a 5th gen replaced their filter yet? I want to know if I shouldn't worry about it. Also, on a side note, where is the 5th gen PCV valve and how can I replace it ???
Old Jun 22, 2002 | 06:17 PM
JoesMAX's Avatar
thats gotta be a pain in the a$$ to have the fuel filter inside the fuel pump... i heard some cars used to have them in the gas tank! thats gotta suck
Old Jun 22, 2002 | 06:47 PM
Virus's Avatar
Premium fuel is required because the Max has a high compression ratio.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
