injen CAI?
Old Jun 30, 2002 | 01:12 PM
rob van dam's Avatar
injen CAI?
is it necessary to disconnect to battery when installing the injen CAI?
ALSO.....where is the MAF sensor located?
thanks
albert
Old Jun 30, 2002 | 01:17 PM
SmokinOdum's Avatar
http://www.cardomain.com/member_page...=211165&page=4
Some pictures of my car with Injen CAI, they should answer your questions.
Old Jun 30, 2002 | 06:25 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
Re: injen CAI?
thanks
albert
yeah i blew my ignition fuse installin mine!
Old Jun 30, 2002 | 09:52 PM
Re: Re: injen CAI?
WTF!!!.....was that because you didn't disconnect the battery?..how much was that to fix?..
thanks
albert
Old Jul 1, 2002 | 08:47 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Re: Re: injen CAI?
thanks
albert
A fuse? That had to set you back like $5!!!
Old Jul 1, 2002 | 09:11 AM
MichaelAE's Avatar
Primary reason to disconnect the battery is that you will throw a CEL if you disconnect the MAF Sensor while the car is getting juice. Make sure you reconnect the MAF Sensor before reconnecting the battery.
Old Jul 1, 2002 | 09:34 AM
emax02's Avatar
As long as you don't turn the car on with the MAFS disconnected you are all set. I never unplug my battery.
Old Jul 1, 2002 | 09:48 AM
MichaelAE's Avatar
My bad...I had the impression that the MAFS didn't like being disconnected when the car was juiced at all. Thanks.
Old Jul 1, 2002 | 10:30 AM
maximadave's Avatar
detailerdaveb@gmail.com
Why do you have to disconnect the MAF sensor and the battery? I didn't have to do this when I installed both my Frankencar and Injen. My "service engine soon" light never came on.
Old Jul 1, 2002 | 10:37 AM
MichaelAE's Avatar
So you did all your work in assembling the intake right there in the engine bay? I think it is much easier to assemble things if you remove the MAF unit from the engine bay. If you leave the MAFS attached, you can't take the MAF unit more than about six inches away from its source.
FYI...my patio is being utilized currently to paint the couplers and tubing for the Injen BLUE.
Old Jul 1, 2002 | 10:43 AM
maximadave's Avatar
Yes, it wasn't that bad to install. Took a little more than a hour to do.
Old Jul 1, 2002 | 10:53 AM
jkratzer's Avatar
Do you all plan to remove your Ingen CAI's when you take your car in for service? Seems like a pain in the *ss if this is the case.
Old Jul 1, 2002 | 10:55 AM
MichaelAE's Avatar
No tougher than any intake. I think the biggest hassle is putting the stock airbox back in...it is a tight fit.
Old Jul 1, 2002 | 11:01 AM
well
i need to disconnect the MAF sensor..where is it located?...i need to know..thanks....when i get my injen...i wont take it out when i get serviced..i dont ever take my stillen out....
albert
Old Jul 1, 2002 | 11:02 AM
maximadave's Avatar
Nope....I know most of the service guys at Mossy in Oceanside. They even installed my Y-pipe and intake for me on my 2K. They were impressed with my Injen intake a few days ago when I had my oil change done there.
Old Jul 1, 2002 | 11:18 AM
MichaelAE's Avatar
Re: well
albert
Looks the same on both 2K-2K1 and 2K2-2K3. This is the photo of a 2K2 with a Franken intake, but that MAF Unit is the stock unit.
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
Dasmith
Aug 25, 2015 10:15 PM
