Highlights
Old Sep 18, 2003 | 04:16 AM
Nyle
Highlights
It looks like the auto on headlight sensor area on the dash can be opened so I can darken it on the inside to make the headlights come on all the time. This would result in daytime driving lights, that would turn off automatically. Has anyone opened the sensor area to do this and if so how is it done? Does doing this void any of the warranty? Thanks for the help. I have a 2004 SE Silver, with the silver interior.
Old Sep 18, 2003 | 08:46 AM
CanadianMoFo's Avatar
Why not try putting some sort of dot over the sensor first? Maybe you can find something that will blend in nicely. There are some new labels that are easily removed, mostly for refrigerators and such. Perhaps one of those, trimmed to a circle and coloured black with a sharpie marker would be perfect.
CM.
Old Sep 18, 2003 | 10:51 AM
nick wolff's Avatar
electrical tape works too. cut it in a circle. thats what i did on my 00
Old Sep 18, 2003 | 04:37 PM
Great idea Nick!
I'd go a step further and cut a smaller circle out of paper and place it inside. Just to cut down on the tape residue that would be left behind. That way you'd only have a small ring to clean up rather than the whole area.
Personally I like the DRL that the 04's have. My personal pet peeve are DRL's. I've gone so far as to remove them from past vehicles I've owned. Since the DRL's are usually high beams at 60% they are aimed poorly, and at dusk and dawn you get glare from oncoming drivers. The Max DRL's are an entirely seperate bulb/reflector, and are diffuse enough to not be annoying.
CM.
Old Oct 10, 2003 | 06:16 AM
bigcozz's Avatar
Cant you just switch you lights on manually?
Old Oct 10, 2003 | 07:57 AM
peetah's Avatar
It would've been great if Nissan left the harness in for the DRL relay. The bulbs are in the headlight assembly but no harness to the relay panel in the engine compartment... unless I wasn't looking hard enough.
Old Oct 10, 2003 | 01:50 PM
bluemaxx's Avatar
Moderator GT-R
An interesting OT:
On Wednesday night I left my headlamps on, on purpose, and after about 3 minutes they turned themselves off. Kinda cool.
Old Oct 10, 2003 | 07:43 PM
ocuihs's Avatar
Originally Posted by bluemaxx
An interesting OT:
That's 180 seconds (max), Did you know that you can program in the following interval: off / 30 sec / 45 sec / 60 sec/ 90 sec / 120 sec / 150 sec / 180 sec.
Old Oct 11, 2003 | 10:42 AM
2K4maxima's Avatar
yea u can just program it to go on automatically.you can make it really sensitive also.but u have to be in park to do it..
Old Oct 11, 2003 | 01:45 PM
bluemaxx's Avatar
Moderator GT-R
Are we talking about the same thing? I left them on in the ON position not the AUTO position. They still turned themselves off. Is that adjustable too just like the AUTO off feature? I'm using the manual to prop up the broke off leg of the sofa...
Old Oct 11, 2003 | 04:45 PM
tonywinsc's Avatar
You should try using the jack, adjustable height.
Old Oct 11, 2003 | 09:13 PM
ocuihs's Avatar
Headlights turned ON and OFF by the driver (no AUTO headlight function); day or nighttime operation. Same operation as Headlight switch in the AUTO position.
Old Oct 11, 2003 | 09:16 PM
ocuihs's Avatar
Nope......you can do it while waiting traffic light for example (not necessarily in Park postition).
Y2KevSE
72
Aug 4, 2008 08:21 PM
Albertt
Jun 7, 2002 09:48 AM
[maxi-overdose]
May 22, 2002 12:16 PM
Nismo87SE
Oct 20, 2001 08:44 AM
Maximus97SE
Jun 4, 2001 11:33 AM
