Roar After Punching On ExpressWay
Old Jan 24, 2004 | 01:45 PM
jdc1203's Avatar
My 04Max Elite AT has a roar sometimes after I punch it on the expressway. If I am going around 75mph and then wish to punch it to say about 100mph for a quick pass then it gets a roar in the front but goes away after the speed drops back down to say around 65mph. The roar will take place if the car is in the Drive or Neutral until the speed gets back down to around 65mph. It doesn't do it everytime so I can't really take it to the shop at this point until it's more regular but just wondered if anybody has noticed this in there Max or do I have a front end or trans problem.
Old Jan 24, 2004 | 09:24 PM
mikenatas's Avatar
mine doesn't roar...took it up to 115 and was disappointed there wasn't a roar...i have punched it like you said, and it doesn't roar...
Old Jan 26, 2004 | 01:28 AM
hofb99's Avatar
Not too clear on the "roar" sound byte. I would think that this would be natural when punching ANY car. Engines rev higher when you punch them, so this is probably normal... Could you be a little more specific w/ your description?
Old Jan 26, 2004 | 08:06 AM
Mike_TX's Avatar
It's called "wind". Close your windows.
Seriously, you need to describe the roar a little better.
Mike
Old Jan 26, 2004 | 08:08 AM
jdc1203's Avatar
Roar is on the downside not the upside
The roar is like a growl and say you punch it from 75mph to 100mph and then let off the gas you can hear it and feel it in the car. It makes a vibration until it quits at around 70mph but not all the time. It might be a bearing or cvc joint going bad and the high rpm brings it out. I guess I will have to wait until it does it all the time until I get back to the dealer. It does it in Drive or Netural so thats about all I can tell you. jdc1203
Old Jan 26, 2004 | 01:43 PM
Mike_TX's Avatar
I think maybe you're right about it being a bearing or cv joint, but it could also be something as weird as a wheel bearing or motor mount. It could also be something as benign as a vibrating exhaust heat shield or fan shroud. Since you've apparently slipped it into neutral to test it, it sounds like it's probably not the trans.
I would probably take it on in to the dealer if I were you. It's not real likely to be something that could damage the car (or you), but it's impossible to tell based on what you've said.
Let us know what you find out.
Mike
Old Jan 26, 2004 | 03:36 PM
nick wolff's Avatar
mine did that on a local highway, took off from 40 to 75 and it sort of screamed. i approached a stop light and let off the gas and onto the break and the car ended up stalling on me, losing power steering and all electrical. it sucked...
Old Jan 26, 2004 | 06:32 PM
jdc1203's Avatar
Thanks for the info Mike_TX. There roar rumble doesn't happen until after I get the car up to around 100mph and the let off the gas and you can hear it cut out after speed drops down. It does have a metal sound to it so I will have to wait until the thing does it regularly before take it back to the dealer or trade it off one. jdc1203
Old Jan 27, 2004 | 08:12 PM
hofb99's Avatar
Best not to wait...especially w/ something that could end up being very serious. Make an appointment and give the svc rep a clear and precise description of the symptoms...although, he/she may be a little apprehensive about taking it up to 100mph on the freeway!!! lol
Old Jan 27, 2004 | 09:01 PM
hotmax97's Avatar
my brothers new altima was doin that it end up been the tranny
nissan had the car for about a week until they found the problem
oh and the tranny was running fine ...
new cars man! it makes you feal like a guinea pig ? ...
Old Jan 28, 2004 | 04:37 PM
jdc1203's Avatar
Great News! Roar Is FIXED!
Took Max to the Nissan Dealer today. The Service Manager and I went on the expressway and I showed him the roar rumble I heard. He said that it sounded like a vibrating part due to wind at high speed. Sure enough it was the black plastic cover that goes over top of the grille "just a cosmetic part". It has four clips that holds it down and they where really lose. So we looked at another 04 Nissan Maxima that had another kind of clip but made the part tight on the car. So he said they would order the correct clips and problem fixed. jdc1203
Old Jan 28, 2004 | 06:42 PM
CanadianMoFo's Avatar
Good to hear! Its always nice when its something simple that won't keep re-occuring.
JRod28
Dec 29, 2023 09:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
1997 Maxima SE
Nov 4, 2000 10:15 PM
JJW95SC
Oct 23, 2000 11:37 AM
AntGVR4
Oct 16, 2000 03:50 PM
