Door Trim Problem - Fixed
Some of you might remember the problem that i had with the paint rubbing off my door trim a couple of days ago:
![](http://images.cardomain.com/member_images/11/web/575000-575999/575648_69_full.jpg)
Since i couldn't screw it up more than it already was, i decided that i would try to paint it yesterday. I went to a local hardware store and tried matching the paint color as close as i could. This is the closest i could find off the shelf:
![](http://images.cardomain.com/member_images/11/web/575000-575999/575648_72_full.jpg)
Since a lot of males are partially colour blind (including me) i asked my wife if she thought that the paint would match the original trim color. She gave a thumbs up, rolled her eyes and away i went.
I pulled on the trim on the door handle. It popped right out. I sanded it first with 320, 400, 600 and then finished up with 800 grit wet/dry sandpaper. I cleaned the trim off with rubbing alcool and let it dry.
I painted it with numerous thin coats to avoid streaking, etc (at least 6 coats if i recall) and waited about 20 minutes between each coat.
I popped the trim back in the car this morning and this is the result:
![](http://images.cardomain.com/member_images/11/web/575000-575999/575648_70_full.jpg)
Here's another pic where i included the door handle to show the paint match:
Doesn't look too bad at all. The fix cost me about $7 for paint and supplies.
Bob
Bob
Originally Posted by JAANND
How did that happen to your door trim? Did you clean it with something that you shouldn't have used? I would like to know so that I can avoid something like that. It looks pretty damn good by the way. Color looks perfect.
JAANND - Take a look here for details:
http://forums.maxima.org/showthread.php?t=312547
Bob
Door Trim
Hi-- I also had a problem with trim paint--- I hung a Yankee Candle Air Freshener on the rear door handlle, and then noticed it looked like the paint had melted and smeared..... It seems the trim had a reaction to the chemicals in the Air Freshener.... Dealer replaced both rear door trims for free.....
The first thing i said to myself after purchasing this damn car was why the hell hasnt nissan used more brushed aluminum like the nice acura tl. i mean the door trims would be a great place for brushed aluminum. as well as where the shift *** goes, that should be brushed aluminum. the center piece around the shift **** is all scratched up for me. i wish somebody would develop after markey brished aluminum parts for this.
theres onluy one place thats brished aluminum, and you cant see it unless the doors are open.
i think the interior is cheap on this car
1. display screen sucks, scratches with any touch to it.
2. cheap paint on the interior trims, comes off with friggin off? i mean thats pathetic.
3.no brushed aluminum?
anyone agree?
anyone agree?
anyone agree?
anyone agree?
and that's the reason why maximas are $2000 cheaper when similarily equipped.
somebody needs to make some aftermarket brushed aluminum so this car can compete with th tl, the tl's brushed aluminum drives me crazy
http://www.dashkitstore.com/details.php?id=1038
http://www.nycdashes.com/cart/custom...cat=439&page=1
Bob
Hmmmm
See I would only like the door trim inserts and the shifter insert, does anybody know is these kits are adhesive or actual replacements for the stock?
I wonder if you can just order parts or if you need to buy the whole kit?
Hre's another site where you can buy just the door handle strips:
http://www.wooddash.com/item/NISSAN_..._MAXIMA_2004_2
Bob
Bob
wow, thats awesome, any idea id they are replacements for the stock or just stick ons for the stock. also i still would like the shifter to be brushed. I wonder if its possible to get just that.
Also, I wonder if they sell the shift area as a stand alone part anywhere.
I also noticed that there is two types of brushed aluminum classic and simulated, not sure the difference.
These door strips are expensive so I am assuming they are actual inserts that clip in and not stick on.
Good luck,
Bob
Maxima30
09-07-2015 06:13 PM
trungg86
09-04-2015 04:58 AM
