maxima rim off-set
Old Jun 19, 2004 | 03:12 PM
JayMAX22's Avatar
maxima rim off-set
I KNOW someone in here knows the lug offset of the SE. I'm about to put some rims on and I would like to know or SEEM like I know what I'm talking about when I'm in the rim shop. I'm staying with 18 inch wheels.
Old Jun 19, 2004 | 06:59 PM
mattlerose's Avatar
34mm-45mm will work fine
Old Jun 21, 2004 | 09:12 AM
JayStarzZ's Avatar
Are you referring to the "lug pattern" or the wheel "offset" ? Bro, you're better off knowing rather than fronting like you know. . find out what your stock offset is and stay as close to that as possible. . theres a huge difference between +35 & +45 as far as offsets go . .
Old Jun 21, 2004 | 11:50 AM
CanadianMoFo's Avatar
The stock offset is +40mm, and can be found if you take off the OEM rim and look around the backside of the spokes.
CM
Old Jun 21, 2004 | 01:49 PM
KCMAXX's Avatar
KC's FINEST
The lug pattern is 5x114.3
Old Jun 21, 2004 | 08:59 PM
{-_-}'s Avatar
what kind of sizes can they accomodate tho? mattlerose already said +35mm-+45mm, what about lug patterns?
Old Sep 5, 2010 | 10:35 AM
04SL's Avatar
Will a 17x7.5 wheel with a 45mm offset (from a newer G35) with a 225/55/17 tire fit a 2004 Maxima ? I currenly have 18x8 245/45/18 and they look great but the ride it too stiff and Im thinking about getting a smaller wheel/bigger sidewall.
Old Nov 20, 2010 | 01:02 PM
derek's Avatar
changing 18" to 17" rim
I am also wanting to change my 04 Max. wheels to some 17" rims & tires from a 09 Maxima. Will they fit & are their any other issues with the swap? The Nissan dealer says to check with the tire dealers. Have you received any further feedback?
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
criminalslang810
Aug 16, 2015 08:12 AM
RealityCheck
Aug 5, 2015 06:18 AM
