seat shifting
Old Jun 24, 2004 | 03:02 PM
lobewiper's Avatar
seat shifting
I know there was discussion about the seat shifting on turns earlier in this forum, but can't find it. What is the fix for this problem?
Old Jun 24, 2004 | 06:32 PM
ethorn's Avatar
I have brought it up before and can't remember anything that fixed it. months ago I was planning on taking the seat apart to figure it out but couldn't get around to it.
Here is the directions for the seat removal that I scanned a while back:
http://www.computerinspirations.com/...at_removal.pdf
Old Jun 24, 2004 | 11:55 PM
Edify11's Avatar
I've felt this "seat shift" a few times, but on mine it feels more like the lumbar support than the actual seat. For those of you with this problem, I'm curious to know if it is the actual seat that shifts or just the lumbar support.
Old Jun 25, 2004 | 09:51 PM
Thereal411's Avatar
I read other posts about the seat shifting when the seat was in the maximum back position, one poster commented on moving it forward a bit seemed to stop the shifting. Is your seatback all the way back when you are experiencing it?
Old Jun 26, 2004 | 11:20 AM
ethorn's Avatar
Mine is most of the way back... I am 6'4" so I can't really comfortably pull it forward much.
Edify11: It is the actual seat that shifts. I too have lumbar movement too. That feels like the seat back is getting caught on a spring or something and then popping out when you lean forward. 2 different problems.
Old Jun 27, 2004 | 03:41 AM
blackmax4's Avatar
I am taking mine to the dealer on Monday to look at my shifting seat. I will repost once they tell me what they did to fix it.
Old Jun 28, 2004 | 08:14 AM
Maxidriver's Avatar
Can't wait for your replay. It drives me nuts. I tried all different way of adjustments. Nothing worked. My dealership said there's nothing they can do. FYI--I have the same issue with my '01 Pathfinder.
Old Jun 29, 2004 | 03:28 AM
blackmax4's Avatar
The service manager told me that even though my seat had the most play they have seen its just a feature of the seat.
Actually they are contacting Nissen support to come up with a solution. The seat is sliding on a back bar . There is no way to tighten this, but he feels if they add a bushing it should tighten the seat up and fix the problem.
When they call me back with an answer I'll repost.
Old Nov 10, 2004 | 05:48 AM
bmcdaniels's Avatar
Drivers seat shifting?
My Max has about 6000 miles on it. Over the past few weeks, I've noticed a "shifting" feeling in the drivers seat when I turn a corner. It's as if the seat anchors are loose and the seat shifts left to right. However, the seat frame is firmly tightened down. If I try to get the seat to move by hand, it seems rock solid. But... It still feels like the seat shifts slightly when I turn corners. It probably happens 50-60% of the time.
Has anyone else experienced this? Any thoughts?
Old Nov 10, 2004 | 08:05 AM
blackmax4's Avatar
I have this feature too. My dealership called Nissan, but it is on the bottom of the list of things they are looking into. Please complain to your dealer about this. Might help if more people complain.
Old Nov 10, 2004 | 09:31 AM
Monotaur's Avatar
I also have this issue, and of course my dealer could never replicate it... it seems to come and go though, with it mostly happeneing when the seat is as far back as it will go. Also, my lumbar support (I think) tends to 'pop' in and out.. something else my fabulous dealer cannot duplicate, although I might bring it in again since it is happening much more frequently lately.
Old Nov 10, 2004 | 01:15 PM
johnsa's Avatar
Same prob here noticed right after buying my car last fall. Dealer could not find anything wrong..
Old Nov 10, 2004 | 01:58 PM
HotHotHot's Avatar
What they said
Old Nov 10, 2004 | 02:52 PM
Mystery's Avatar
My seat does it all the time, i've just gotten used to it.
Old Nov 10, 2004 | 03:11 PM
CanadianMoFo's Avatar
I had the dealership look at mine. They said that it was where I set my seat position. If it is set at the furtherst forward or furthest backwards it doesn't shift. I tend to believe them. Its likely just a matter of where the seat it set on the track. I know it shouldn't matter, that the seat should be built to take that into account, but thats the way things are. I don't think there is a fix for that.
Just like how the shroud around the wiper/turn signal stalks is not quite level. Mine slopes down ever so slightly to the right side. Its not dead even when you compare it to the instrument cluster. Again, no fix for that, just the way things are.
CM
Old Nov 10, 2004 | 05:23 PM
bmcdaniels's Avatar
You know, the more I pay attention to it, it almost seems like what I'm feeling is inside the seat bottom. Like there is something loose there and it shifts. I wonder if there's anything in the seat bottom that might cause this.
Old Nov 10, 2004 | 08:48 PM
MaxMus's Avatar
this is normal. i had it on my 2000 Max as well. it is definately more noticeable on this Max. it does feel like something inside of the seat itself.
Old Nov 11, 2004 | 05:29 AM
bmcdaniels's Avatar
Out of curiosity, how many of the folks having this issue have leather seats?
Old Nov 11, 2004 | 05:37 AM
blackmax4's Avatar
I have the leather seats. The dealership told me it was moving on a rod in the back of the seat. Mine was the worst they had seen. They called Nissan and was hoping to get a approval to put some rubbing bushings where the slipage was. This was over the summer and I forgot to ask last month when I brought the max in for an oil change. Hopefully I will remember the next time.
Old Nov 11, 2004 | 11:26 AM
bmcdaniels's Avatar
Interesting. Mine are leather too. I was wondering if the seat cover might be what's slipping. I'm not sure how to tell, since it is a very subtle thing.
Old Nov 11, 2004 | 01:18 PM
lobewiper's Avatar
Mine does it--has the heated seats. Does the heated feature have any connection to this problem?
Old Nov 12, 2004 | 07:12 AM
bmcdaniels's Avatar
Mine has heated seats too. I wonder if that's the common issue. maybe something in the mechanism moves around.
Old Nov 12, 2004 | 12:24 PM
MZagoren's Avatar
Hi,
I'm new to these forums and own a 2004 Maxima.
I had the same issue with shifting and cracking in the seat. The dealer replaced the seat bottom and all is fine now.
Matt Zagoren
Old Nov 12, 2004 | 02:15 PM
lobewiper's Avatar
Originally Posted by MZagoren
Hi,
Matt Zagoren
Matt, do you have the heated seats option?
Old Nov 12, 2004 | 07:09 PM
MZagoren's Avatar
Yes. And just to clarify, the "cracking" I was referring to was a noise and not a visible crack in the seat itself.
Old Nov 13, 2004 | 09:21 AM
Monotaur's Avatar
I also have heated leather seats... hmm...
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
sliptap
Sep 30, 2015 05:57 AM
