Sunroof Problem
Old Jul 11, 2004 | 06:54 PM
SilverSL's Avatar
Sunroof Problem
damn man.,. my sunroof will not close, It will close then open half way and stay there, its really starting to bug me because its 11:30pm and it will rain after midnight!!!!!!!! anybody else had this problem?? gonna call the dealership in the morning but stil lwanna know if its happened to anyone else.
Old Jul 11, 2004 | 07:07 PM
xpmax's Avatar
Yup. The deflector is jamming up. You can get around this by repeatedly pressing the sunroof tilt button (not the slider, the other one). Just make sure that deflector doesn't bunch up. This is a known issue.
Old Jul 11, 2004 | 07:30 PM
ethorn's Avatar
There is a TSB on this if it is the deflector. See the TSB post and goto the link that starts with theowensfamily. You should see it there.
Old Jul 12, 2004 | 11:11 AM
Mystery's Avatar
I've had the same problem for almost a year. Its been fixed, but only worked for a whopping 20 mins. It would hit the deflector then bounce back. Then you use the tilt button to close it the rest of the way.
This is very frustrating but i did find an easier way to deal with it. When you are closing it with the slider right before it comes in contact with the deflector hit the tild button. Then press it again and it should close on the first try.
Until it is completely fixed, i hope that helps.
Old Jul 12, 2004 | 06:01 PM
ethorn's Avatar
you don't have to close it with the slider at all.... I don't to save wear on it, instead I push the close button on the tilt selector, then when I want to open it I push the slider one position over and then to where I want it.
Given what Mystery_Man said I would say just use the tilt open button then use the tilt close button after it sits in tilt open mode. But take it to your dealer and get it fixed.
Mar 12, 2020 12:06 AM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
