How Do I Hook up an amp to my stock radio?
Old Aug 1, 2004 | 08:41 AM
F98sentra's Avatar
I want to add a amp to my stock radio so I can run a set of subs. I don't have the Bose stereo or Sat set up, I just have the stock NDSS system. I do have the Sat button but as far as I know nothing is hooked up to it. I tried a PAC SNI-35 which does not work it just turns the subs on but no music goes through them. I have no idea what to do.....Please HELP.......
Old Aug 3, 2004 | 10:29 AM
andymax95
The other option is to tap into the rear speaker with a high/low converter and run your RCA's from there. The quality won't be great cause because the outputs aren't directly processed from the headunit meaning you may have loud bass when the volume is low. But it works
Old Aug 3, 2004 | 04:09 PM
scavynger's Avatar
I did it this way, and it sounds pretty good. Can't compare it to how it would sound straight from the max's stereo, but it definitely sounds as good as it did in my last car hooked up to a kenwood stereo. For most case scenarios, I would say you'd be satisfied with it. But maybe if you were hardcore into sound, you might notice it lacking.
litch
123
Jan 4, 2024 07:01 PM
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
