View Poll Results: Which Intake is the Best?
Injen
33.13%
Stillen
18.75%
Berk Tech
32.50%
Other
15.63%
Voters: 160. You may not vote on this poll
Which Intake?
Old Aug 11, 2005 | 06:16 PM
  #121
savagecat's Avatar
Going Ginsu
Originally Posted by NmexMAX
It's because it should look like this
An actual RUN FILE from dynojet.
IT'S EXCEL! IT'S EXCEL!
Old Aug 11, 2005 | 06:20 PM
  #122
E55AMG2's Avatar
Wat
if you arent careful
Old Aug 11, 2005 | 06:25 PM
  #123
E55AMG2's Avatar
Wat
Originally Posted by darrinps
Several posts back I mentioned wondering if a CAI really brought in cooler air.
Here is an interesting thread from another board on that topic that will shed some light on it:
http://www.b15sentra.net/forums/show...ature+CAI+test
Long story short, this guy measured the temp and at speed (not sitting on a dyno) the temps are about the same.
Now, had he measured on very hot days, I bet that the CAI may actually have shown a higher temp than the pop Charger given the heat coming off of the pavement.
So, IMHO, modified stock or pop charger is the way to go...of course, it may not look as nice as that $200 CAI setup.
You can do the same test and eliminate those variables by using the OBD IAT
Old Aug 11, 2005 | 06:28 PM
  #124
savagecat's Avatar
Going Ginsu
So that's your argument?
Old Aug 11, 2005 | 06:34 PM
  #125
E55AMG2's Avatar
Wat
I don't need to understand how every little piece of a dyno works to accept multiple results from different companies. It would be like asking you to know how the internet works so you can hit the "Reply" button.
If you wish to blindly accept whatever you read in a magazine, go ahead. However, if you wish to have an intelligent discussion, it would be wise to go learn about dynamometers and study the shapes of nissan power curves. You will be surprised how many "dynos" are fake.
You finally give something of substance by giving the link for local dyno shops. After cold calling a bunch of shops from the yellow pages I'd only found one up by Columbia.
So far, everything Ive given you has been of substance. Now, go get some pulls before/after and lets put this thing to bed. I have some runfiles I can send you, if you are interested in seeing them. A back to back with stock airbox w/ a k&n and a popcharger.
Old Aug 11, 2005 | 06:35 PM
  #126
E55AMG2's Avatar
Wat
No, but if you insist upon maintaining your level of ignorance and attempting to carry on a discussion of a technical nature, I might just have to.
Old Aug 11, 2005 | 06:39 PM
  #127
savagecat's Avatar
Going Ginsu
Again, if multiple sources are used, then someone claiming 'fake' doesn't have much credibility. The discussion was intelligence until banning me came to the forefront. You showed yourself.
Nope, it's been your opinion whereas the companies have backed theirs up with proof.
Old Aug 11, 2005 | 06:40 PM
  #128
savagecat's Avatar
Going Ginsu
Because I'd rather believe supported sources than word of mouth?
Old Aug 11, 2005 | 06:43 PM
  #129
E55AMG2's Avatar
Wat
Ive got the runfiles, if you are willing to DL the free software.
Old Aug 11, 2005 | 06:44 PM
  #130
E55AMG2's Avatar
Wat
Alright, if their dynos are indeed legitimate then you should be able to repeat their results...right? With that in hand, find yourself a dyno shop and lets put this to bed
Old Aug 11, 2005 | 06:45 PM
  #131
E55AMG2's Avatar
Wat
Just like the CIA had supported sources for WMD.....
Old Aug 11, 2005 | 07:05 PM
  #132
maximob's Avatar
After reading this I can see the benefit of CAI in city or suburbia driving where you tend to sit at stoplights alot. It would keep the added power more consistent. The only question now is ... INJEN or AEM??
Old Aug 11, 2005 | 07:45 PM
  #133
motometal's Avatar
uhmmmmm, helllooo? doesn't the stock intake draw "cold" aire frim just under the hood, away from the air heated by the engine/under the hood? What's wrong with that? It sucks just because it is stock?
Old Aug 11, 2005 | 08:37 PM
  #134
E55AMG2's Avatar
Wat
That would be the thinking in here
Old Aug 11, 2005 | 10:59 PM
  #135
savagecat's Avatar
Going Ginsu
Unlike in this case where it can be backed up.
Old Aug 12, 2005 | 03:18 AM
  #136
motometal's Avatar
teach me, I want to learn. Most of the pictures of "cold air intakes" I have seen are just a big open filter under the hood where the air will be HOT. Makes no sense. What am I missing?
Old Aug 12, 2005 | 05:31 AM
  #137
darrinps's Avatar
I think what you saw was a pop charger not a CAI.
The "true" CAI extends downward (extended tube).
If you check the link I gave you though, a CAI really doesn't buy you much as far as air temp unless you sit at a stoplight for a long time or are on a dyno. They may (hasn't been proven...just a theory) even do worse than a Pop charger on a hot day whee the pavement radiates a lot of heat.
Old Aug 12, 2005 | 05:42 AM
  #138
darrinps's Avatar
Given that the air will cool down quickly around the pop charger anyway, and the fact that the extended tube of the CAI is being heated up (it is up high..won't add much to the air temp, but thought it should be mentioned), I really doubt there is enough difference to worry about.
If you wanted the best setup, I'd either modify the stock one to remove the snorkel neck down restriction (may not be easy to do...never tried) or simply get a pop charger and seal it off.
Old Aug 12, 2005 | 05:44 AM
  #139
darrinps's Avatar
I think that is very good advice.
Old Aug 12, 2005 | 07:13 AM
  #140
E55AMG2's Avatar
Wat
So far, the only true cold air was made by Place Racing (no longer making parts for cars). To install it, you actually had to drill a hole through the inner fender into the open area in front of the LF wheel well. The main issue with them was that they came with monsterflow foam filters.....which didnt really filter that well and caused restriction at elevated RPM. Anyways, shoot me a PM and we can finish talking about this.
Savagecat: Until you post a Dynojet runfile, noone here is listening to you.
Old Aug 12, 2005 | 08:45 AM
  #141
savagecat's Avatar
Going Ginsu
You've got big chip on your shoulder against dyno results for whatever reason. Link after link has been provided for your benefit and yet you still don't want to listen.
Old Aug 12, 2005 | 09:14 AM
  #142
Jeff92se's Avatar
I'm needing a caw
If the dynojet machine automatically converts the data into a runfile, when why would these "other" dyno runs be in excell?
Old Aug 12, 2005 | 11:55 AM
  #143
E55AMG2's Avatar
Wat
Because savagecat says so. I bet hes the kind of guy that believes the car salesman saying that they have another buyer on the car he is looking at.....
Old Aug 12, 2005 | 12:17 PM
  #144
darrinps's Avatar
Well...(and I'm not saying this IS the case, only one possible answer) it depends on what they use as their tool of choice for publishing.
Some places use Adobe, some use Word. If they set up their articles as word documents and don't want to scan in the image then it would explain it.
Again, not saying this is the case...just one possible answer as to why.
BTW, I am still waiting to hear back from Nissan Performance Magazine as to the real reason (I wrote them yesterday).
Old Aug 12, 2005 | 12:18 PM
  #145
SeaFoam2DMax's Avatar
Oh hi....
holy cow, I cannot believe I just read all of this again. ATTN:4th genners, you no longer have a monopoly on stupidity on the .org, savagecat has taken a large percentage of it to the 6th gen forum. btw savagecat, you gene pool could use a bit of chlorine.
Old Aug 12, 2005 | 12:21 PM
  #146
darrinps's Avatar
Now this is OT, but why do folks here go in for personal attacks like this?
He has an opinion, others have theirs. Can't we keep it civil and on topic?
Calling someone stupid won't get us the answer.
Old Aug 12, 2005 | 12:24 PM
  #147
E55AMG2's Avatar
Wat
You can take screenshots of the runviewer and put them into ANY type of document....
Old Aug 12, 2005 | 12:26 PM
  #148
E55AMG2's Avatar
Wat
The answer already exists....as many before you have seen the results of what intakes can do, ask SR20DEN. It seems his act was one of frustration...its like telling a little kid monsters dont exist, they just dont listen
If youre talkin bout nissanperfmag.....im interested to see what you get back
  #149
darrinps's Avatar
I'm aware of that...believe me...I know about that sort of thing. I'm just playing Devil's advocate waiting to hear what (if they respond) the magazine says.
Old Aug 12, 2005 | 12:27 PM
  #150
E55AMG2's Avatar
Wat
Id love to them for publishing that BS
Old Aug 12, 2005 | 12:28 PM
  #151
Jeff92se's Avatar
I'm needing a caw
How about this. What if they have the runfile and instead of just making it a screen shot and putting into the article, they have to plot out each point twice and take 4x the time. Somehow that doesn't make too much sense
Old Aug 12, 2005 | 03:28 PM
  #152
savagecat's Avatar
Going Ginsu
It's not uncommon to export data. Why have users install software to check out a runfile.
Old Aug 12, 2005 | 03:29 PM
  #153
savagecat's Avatar
Going Ginsu
Aw ... AMG had to call in for reinforcements and you obeyed.
  #154
Jeff92se's Avatar
I'm needing a caw
Why not just take a screen shot?
Old Aug 12, 2005 | 03:30 PM
  #155
savagecat's Avatar
Going Ginsu
SR20DEN? ROFL.
Old Aug 12, 2005 | 03:32 PM
  #156
savagecat's Avatar
Going Ginsu
F*** if I know why a screenshot wasn't used. But AEM averaged three out.
Old Aug 12, 2005 | 03:34 PM
  #157
Jeff92se's Avatar
I'm needing a caw
Exactly............ Makes me wonder.
Old Aug 12, 2005 | 03:58 PM
  #158
savagecat's Avatar
Going Ginsu
But it's not uncommon. I spoke with AEM and the runfiles are proprietary so they're not coughing them up. I don't really find that odd, it'd be like asking Microsoft to cough up code for SourceSafe.
Old Aug 12, 2005 | 04:02 PM
  #159
Jeff92se's Avatar
I'm needing a caw
So why not just take a screen shot and send it as a jpg file?
Old Aug 12, 2005 | 04:44 PM
  #160
savagecat's Avatar
Going Ginsu
I'll ask them Monday. The worst that can happen is they say 'no'.
