What's the tire pressure for 20 x 8.5 wheel with 255/35/20 tires?
Old Jan 7, 2005 | 09:03 AM
queenzkid's Avatar
What's the tire pressure for 20"+ rims? These aftermarket wheels and tires do not come with specs on pressure. Tirerack says overinflation is good for track running, but with the bumps in nyc, it is throwing off the alignment.
Old Jan 7, 2005 | 03:21 PM
carcus's Avatar
I use 32-35 PSI on my 20" rims. That should be good for you. With 20" rims in NYC.....a few PSI will not make much of a difference if you hit that pot hole "just right".....if you know what I mean. Still, keep them no lower than 32 PSI. With lower profile tires, takes a bit more pressure checking than stock.....especially in winter when you tend to lose a bit of pressure as the norm. Hope this helps.
Old Jan 7, 2005 | 03:23 PM
carcus's Avatar
And as far as overinflation for track running.....that ruins traction.....plus, if you run 20" or higher rims.....running the track is kinda pointless in my opinion. Better off running 17" rims or lighter weight rims.
Old Jan 8, 2005 | 12:17 AM
lightonthehill's Avatar
I agree with carcus that 20" rims are for 'show', not 'go'.
Old Jan 9, 2005 | 07:00 PM
jonniewaka
WHAT ARE THE OFFSETS..IW AS THINKING TO BUY 20 OR 19..BUT WHAT ARE THE RIMS SPECS..7.5 OR 8.5 WIDE??OFFSETS mm?? TIRE SIZE..PLEASE HELP A NOOB..AND ANOTHER THING IS WHERE CAN I GET A SUNROOF DEFLECTOR..?DID THE 20 JUST POP ON??OR MADE ADJUSTMENTS FROM INSIDE OF FENDER?
Old Jan 13, 2005 | 01:17 PM
queenzkid's Avatar
I had 34 and then 32 psi. Both times, I felt every single bump in the road. It made the shimmy more noticeable. What about 31? Is this considered underinflated??
matts95max
Apr 23, 2025 10:44 AM
MR2 T'd
Jul 9, 2021 05:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
