aftermarket pillar vane rotors
Old Jan 10, 2005 | 04:38 PM
ethorn's Avatar
I am getting a little tired of my rotors warping. They were warped pretty bad starting around 11K but the original tech said they weren't that bad and told me I was over 11K so they were no longer under warranty. At about 22K I took it in because of an engine noise (high pitch rattle/slipping just below 3K RPM). The manager (Team Nissan, Chris Bruder) test drove it tyring to figure out what it was. Well they couldn't figure out where the noise was coming from but he did fix my rotors by shaving them under warranty. But now with 30K I have the rotors warping again.
Are there any good quality OE sized rotors?
Old Jan 10, 2005 | 05:34 PM
Smoken'04's Avatar
#1 the tech lied. 9 times out of 10, your brakes are warrantied up to 12k, not 11k. I'd look into somethin like stillen or to that effect
Old Jan 10, 2005 | 06:38 PM
russgriz's Avatar
I've had front brake rotor warping on many different makes and models of cars. This is usually due to the fact that the rotors are cast. When cast, there exist in the rotors stresses from the metal colling at different rates. Once the rotors have been heated up by breaking a few times, these stresses act to warp the rotor. Usually, 1 turning will fix the problem since, by that time, the rotors have heated up enough to relieve most of the stress areas in the rotors so oce the have been turned or re-finished, you should be good.
However, once I rech the point where I can no longer get break work done under warrenty, the first thing I do is go out and get new rotors from....are you ready for this?...Autozone. Just get the standard set they sell. Most are made in Canada where they cast oversized rotors...HEAT them...then turn them down to specs. I have never had a warping problem with rotors from Autozone and I have done this on three different cars. I swap out the rotors myself since, with a Haynes or similar manual, the work is quite easy and doesn't take special tools (usually). Total cost for doing it myself is A LOT less than having the dealership do the work, even if I have to buy a tool or two to do the work myself, plus I get to keep the repair manual.
Old Jan 12, 2005 | 12:48 PM
ethorn's Avatar
I have had a fitting problem with them on a 02 Cherokee.
And Smoken'04, Do you know if stillen does anything other than drill the nissan rotors? I have heard reports on this forum stating that the stillen rotors are nissan's rotors that have been cross drilled. And if the normal nissan rotors warp, what makes these any different?
Old Jan 12, 2005 | 12:54 PM
Glude's Avatar
So were can we get aftermarket rotors? Ive heard Irotor makes them, but doesnt have them listed on their site. Also on ebay a guy has a listing for 04-05 brembo rotors but they dont have them listed on their site either so apparantly that guy doesnt know what hes selling. I NEED rotors bad and cant find anything worth buying. Maybe a maxima.org sponsor could help us out.
Old Jan 12, 2005 | 10:11 PM
nick wolff's Avatar
BLING BLING.
stillen got em for $280 front i believe and $205 for the rear.
around 15k on em, and still no warpage.
Old Jan 13, 2005 | 12:52 AM
Glude's Avatar
Im not buying OEM drilled rotors. The quality of the stocks suck.
Old Jan 13, 2005 | 09:03 AM
Viper1's Avatar
Has it been verified that the Sillen rotors are just OEM rotors that have been cross drilled. I have been looking for replacements for mine also.
Viper1
Old Jan 13, 2005 | 10:55 AM
Glude's Avatar
Yes it has been verified.
Old Jan 14, 2005 | 08:35 PM
Viper1's Avatar
With so many complaints with the stock rotors, why won't someone in the aftermarket community made a replacement? They would make a killing.
Old Jan 14, 2005 | 11:22 PM
DeusExMaxima's Avatar
can someone find out if Brembos from G35 fit?? Also, try www.performancenissan.com for aftermarket brakes from AP Racing
Old Jan 15, 2005 | 11:38 AM
Viper1's Avatar
Nothing on the www.performancenissan.com to browse for parts.
Old Jan 15, 2005 | 12:02 PM
James92SE's Avatar
2 VE's are better than one!
I've had Stillen x-drilled rotors on my 3rd gen for years now, but mine are drilled Brembo's..
Old Jan 15, 2005 | 12:31 PM
slizan99's Avatar
your brake rotors should be covered up to the 36,000 mile warranty. i've done several maximas in the 20-30,000 mile range under warranty.... come to think about it, I worked on a 04 max with 21,000 miles for the brake shimmy yesterday. it was covered under warranty. by this point in time, I would have just replaced the rotors under warranty.
Come to Regal Nissan in Roswell. PM me if your interested and i'll tell you who to talk to.
Jake
Old Jan 15, 2005 | 02:38 PM
Sorry, wrong link. Performance Nissan link is http://www.perfnissan.com/parts.shtml
Try that.
Old Jan 15, 2005 | 03:10 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
You can also try getting them here. Page 2.
http://www.cardomain.com/memberpage/342829/2
Apr 16, 2020 05:15 AM
chisam14
Nov 6, 2018 08:56 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Socalstillen
Sep 26, 2015 12:01 PM
