Stillen front strut tower bar
Old 03-17-2005, 08:50 PM
  #41
SuPeRmOd
NismoMax80's Avatar
wow, I'm feeling your new grille. but come on, you have to bronze or black it. (esp w/ the wheels) that grille is at the top of my list when I feel a need for grille change. but i'll want powdercoat black....
bar looks great. how's she feeling now? any rubs?
NismoMax80 is offline
Old 03-17-2005, 08:54 PM
  #42
Jayzmax04's Avatar
Dues, the grill looks pretty good.
Noticed they still have to paint your front lip, why not just have them paint the grill at the same time? ALL BLACK- HOT!!
Jayzmax04 is offline
Old 03-17-2005, 09:34 PM
  #43
DeusExMaxima's Avatar
Jayz: Thats exactly what Im going to have done. Im going to have the body kit, grill and those two chrome strips on the roof all painted black. Im also goning to have the badge on the back removed and the holes filled and painted.
DeusExMaxima is offline
Old 03-17-2005, 10:59 PM
  #44
VTmaximaVT's Avatar
nice max, DeusExMaxima!!
now. let me ask you some questions.
I'm pretty sure you've been asked this same questions many times before.
sorry, but I'd appreciate if you spend some time to answer my questions
1. how do you like the CE y-pipe? sound-wise? performance-wise? can you
pass emission test with the CE y-pipe?
2. how does the Stillen front lip fit? do you see any gaps between the front
bumper and the lip? and how's the quality of it?
thanks!
VTmaximaVT is offline
Old 03-18-2005, 01:00 AM
  #45
CE pipe feels better, more response. Terrible kink in the stock pipe. NO difference in sound at all. Will not pass emissions as the cat is removed unfortunately, but its easy to swap if u need to.
Stillen body kit was NOT installed. I fit it on there just for pics to see how it would look. It fits without any fasteners, so good fit. U have to remove ur mudflaps. Looks great in person. Im looking for a place to paint it along with my GRILL which also looks waaaay better in person. The grill will be blackend. Maybe I should powdercoat.
Old 03-18-2005, 01:02 AM
  #46
The bar is rubbing, a lot. When I back up and when I deccelerate into a turn. Lots of buzzes that werent there before. Im going to keep it on a bit to see where it rubs exactly. Not happy that I should have to grind on things. More R & D should have been done.
Old 03-18-2005, 04:31 PM
  #47
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
throw some washers under the strut mounts and prop it up. don't grind it altho is prob a small piece to grind.
Tek-Niq is offline
Old 03-18-2005, 05:19 PM
  #48
SuPeRmOd
NismoMax80's Avatar
no, then he'll rub his hood.
some rub the manifold, some rub the hood, some not at all.
could we come up with some kind of insulation instead of grinding?
spoke to Stillen, of course they have no experience with, or have heard anythign about rubbing.
Old 03-18-2005, 05:24 PM
  #49
Tek-Niq's Avatar
of course they haven't.... I'm trying to pass on the washer info cause I saw pics of someone who did it, but those pics I didn't save I was just looking around... but if we have hood issues as well all there is left is to try all the options we come up with until one works for all........
Tek-Niq is offline
Old 03-18-2005, 05:29 PM
  #50
SuPeRmOd
NismoMax80's Avatar
yeah, I agree with you. so it comes down to "If you have a rubbing FSTB:" use washers to raise and provide clearance of the manifold. If that causes hood rubbing (or you originally have hood rubbing) grind these spots or ????????????? [maybe some kind of bushings or bumpers on the hood]?
Dammit, now I'll have to make a "Problems with 6th Gen MODS" Sticky.
Old 03-18-2005, 05:40 PM
  #51
Tek-Niq's Avatar
hahaha, I hear you... you are about to find out for yourself soon when you get the bar from Glude.... try and find out a way without grinding, I don't feel that at all. specially when the bar is expensive as is... we'll see soon...
Tek-Niq is offline
Old 03-18-2005, 06:18 PM
  #52
Grinding the manifold carefully should be less obvious than grinding the bar. Im going to try that first I think.
Old 03-18-2005, 09:01 PM
  #53
Old 03-19-2005, 07:36 AM
  #54
04BlackMaxx's Avatar
I think Ill just go for the rear swaybar after seein this...I still need to get the skyview changed, I might as well ask the service department if they'll install it, some do some dont ya say?
04BlackMaxx is offline
Old 03-19-2005, 07:48 AM
  #55
Tek-Niq's Avatar
the skyview is a recall, dealer will do it.. if you meant the swaybar done by the dealer they won't do it..
Tek-Niq is offline
Old 03-19-2005, 08:16 AM
  #56
SuPeRmOd
NismoMax80's Avatar
sure they'll change it. unless their afraid that "It may void your warranty". which is dumb b/c we already have a RSB.
a few on here have nice dealers that did it for $60.
My dealer is decent and all, but are out for money. they had the nerve to quote me for 2.5 hours labor resulting in more $$$ than the price of the bar.
Old 03-19-2005, 08:30 AM
  #57
SilverBelle04's Avatar
A tire shop charged me about $60 or about 1/2 hour labor. It's a very quick and easy install
SilverBelle04 is offline
Old 03-19-2005, 08:31 AM
  #58
Tek-Niq's Avatar
cool, my dealer won't do ****. I think I'm going to go to another one that I used to go to..
Tek-Niq is offline
Old 03-19-2005, 08:40 AM
  #59
Yeah, Im thinking id go to the dealer and let them do the skyview, while at the same time putting the RSW while im there. I wouldnt be suprised at a no of course..but I feel best taking the car to the dealer for things like this, rather than someone whose never worked on one.
Old 03-23-2005, 09:41 AM
  #60
GMaxD's Avatar
Grinding the bottom of the strut bar where it rubs is the best thing to do.Putting washers will make the bar rub against the hood. The plastics covers? Cut it. Not that difficult.Thanks.
GMaxD is offline
Old 03-23-2005, 11:58 AM
  #61
I only had to cut a small piece from the drivers side plastic cover. The passenger side cover fit fine with not cutting.
Old 03-23-2005, 02:04 PM
  #62
05MAXSE's Avatar
I installed mine Saturday and no problems after cutting the corner near the ac lines and placing washers on the bolts. Also had to cut both hood ledges.
05MAXSE is offline
Old 03-17-2006, 02:35 PM
  #63
Killah Kane's Avatar
Bending the A/C pipe??? How???
Everyone is talking about the rubbing of the manifold, but no one at all talked about bending the A/C pipe on the passenger side so that the stut bar ring will fit on the strut properly. I just got my bar and I want to install it, but I was looking at my a/c pipe and how the hell do I suppose to bend this? It is very stiff and I dont want to break it, what do I do????
Killah Kane is offline
Old 03-17-2006, 03:21 PM
  #64
*moderator*
jsmithsole's Avatar
I just had to nudge past it and it was fine. I though about that as well when I was installing mine but nothing broke...
jsmithsole is offline
Old 03-17-2006, 04:03 PM
  #65
It doesnt seem that there is enough room to nudge past my a/c pipe on my car. It is really in the way of mounting the strut bar ring. How can I bend it? You didnt have to bend yours? BTW I have a stillen front strut bar.
Old 03-17-2006, 04:27 PM
  #66
gen2000's Avatar
Try This.
http://www.nissanperformancemag.com/august04/altima/
Should be the same procedure.
gen2000 is offline
Old 03-17-2006, 11:57 PM
  #67
*moderator*
jsmithsole's Avatar
I didn't have to, I'll have to look again in the morning. I know I didn't bend anything though....
Old 03-18-2006, 04:44 PM
  #68
Thanks for all the help with the a/c line. Now my problem is that the bolts on the strut towers are too tight for me to open. I already broke one of my sockets too trying to open it. How did you guys loosen the bolts?
Old 03-23-2006, 07:16 PM
  #69
Finally! My strut bar is installed! Jeez what a pain for such a simple mod. I didnt even have to shave the intake manifold down at all. It fit fine. I do notice better handling, my next step is probably the rear sway bar.
Old 03-23-2006, 09:05 PM
  #70
*moderator*
jsmithsole's Avatar
Well probably too little too late but I looked again and I just removed the line from that plastic clip and it naturally just moved over a bit...
Get the RSB, I was surprised at how much difference the rear made, way more noticeable than the front!!!
Old 03-23-2006, 10:58 PM
  #71
Has anyone tried the Koni and KYB high performance struts from activetune?
Old 03-24-2006, 07:42 AM
  #72
Glude's Avatar
Ive got the rear agx and some brand new gr2s sittin in the living room. Been on the agx over and year and they rock, im sure the gr2s will be a lot better than the oem fronts. Anways I think I might be getting those ksports off maximaghost so this stuff will be up for sale soon along with the eibachs.
Glude is offline
Johnny9595
09-03-2015 05:18 AM
Stagnet04
08-30-2015 07:30 AM
MaxStock
08-14-2015 10:01 PM
MaxStock
08-14-2015 09:59 PM
MaxStock
08-08-2015 01:18 AM
Quick Reply: Stillen front strut tower bar
