Suicide trunk hinges
Old Feb 23, 2005 | 12:10 PM
ramberg's Avatar
GrandPa
Does anyone know where I can get Suicide trunk hinges. Thanks Warren
Old Feb 23, 2005 | 12:35 PM
Mystery's Avatar
I think you read my mind. I was thinking of this just the other day. I know they got them for other years. My only conern is that the trunk, with at least my spoiler weighs a lot. Quite heavey not sure if the hinges would support it enough.
Old Feb 23, 2005 | 02:35 PM
ramberg's Avatar
GrandPa
Some body has to know. I went thru web sites and I can't find any. I wanted to get Suicide doors but they want 3,000 dollars. If you happen to find them please let me know. Later Warren
Old Feb 23, 2005 | 03:33 PM
KCMAXX's Avatar
KC's FINEST
Warren, you trying to do something like this? I tried doing this a long time ago but gave up. On the other gens they have the arms for the trunk, the guys Ive talked with bought cheap hinges from home depot and mounted them to the lid. Our cars have shocks, so I guess if you could find some arms it could work...?
Mike
Old Feb 24, 2005 | 02:38 AM
ramberg's Avatar
GrandPa
Mike thanks alot for the advice. Later Warren
Old May 7, 2006 | 05:11 PM
ChinoX's Avatar
Bring it B*tch!
From: Queenz, nYc CarClub: NYCMAXIMAS.ORG Website: www.ChinoX.net
Warren man, if that's how you want to go...just let me know:
Old May 7, 2006 | 05:18 PM
NismoMax80's Avatar
SuPeRmOd
um, i don't think anyone made them for us since we have shocks and not hinges. get Redline to make them for you or talk to the other guys about homemade ones.
Old May 7, 2006 | 05:20 PM
DeusExMaxima's Avatar
Is there a way to upgrade trunk shocks for those with spoilers?
Old May 7, 2006 | 05:23 PM
NismoMax80's Avatar
SuPeRmOd
i've thought about that since my chromed-brass plate frame alone makes it slam shut. I say just find any higher pressure shock in a yard or something.
Old May 7, 2006 | 05:44 PM
po8pimp's Avatar
http://cgi.ebay.com/ebaymotors/JDM-A...spagenameZWDVW wow that was easy to find..... and looks easy to install.....
Old May 7, 2006 | 05:50 PM
po8pimp's Avatar
http://www.thehoffmangroup.com:16080...?itemid=FLIPTR this is by autoloc who is extremely famous for their suicide doors... they even have an installation step by step if you want...... my suggestion is buy the ones off of ebay and use their step by step and if it's hard to understand use autoloc's instructions they have good pics to help in figuring it out...... good luck..... post pics k....
Old May 7, 2006 | 05:56 PM
ChinoX's Avatar
Bring it B*tch!
Forgot you guys had shocks
Old May 7, 2006 | 06:16 PM
po8pimp's Avatar
let me get together a quick sketch of what you would have to do even with the shocks.....
Old May 7, 2006 | 07:56 PM
RHMax's Avatar
Newbie just Registered
Okay, I had a different thought about the suicide trunk before I read the thread. I thought Ramberg meant reverse openning like for convertible tops, not flip-flop.
Old May 8, 2006 | 04:03 AM
ChinoX's Avatar
Bring it B*tch!
Def. different idea, but will be too heavy for hinges and more difficult to see inside the trunk at shows etc..
What if you remove the shocks and flip it the same way you would as the 4th and 5th gens?
Old May 8, 2006 | 01:11 PM
luigi'smax's Avatar
as estated before, it might make it harder to see inside the trunk and maybe even hard to use the trunk in any way but i think that look would be soooo freaking cool...just me..
now, for what i read/heard before...we cant do this... because of the shocks and also because we basically have no space for the hinges to be supported inside the trunk...yeah i guess there are many places and ways to secure it and make it work but i guess it is not only about making it work but also about making it look good and functional... i still think the convertible top trunk would be soooooo hot... interesting look...
Luigi
Old May 8, 2006 | 08:30 PM
whitestunna's Avatar
http://cgi.ebay.com/ebaymotors/Nissa...QQcmdZViewItem
there is what your looking for i guess. not that expensive either.
Old May 8, 2006 | 10:30 PM
ramberg's Avatar
GrandPa
I sent them a email. I want to see a picture of this installed on a 6th gen. I will let you know if they get back to me
Old May 8, 2006 | 10:45 PM
jsmithsole's Avatar
*moderator*
...and you get a free "Horsepower SpeedChip Upgrade" all for under $30!!
I think this will be a cool mod if done correctly...
Old May 8, 2006 | 10:58 PM
po8pimp's Avatar
ok bear with me.... I have put together a couple quick sketchs to show you some ideas of what you would have to do..... this took me a bit to play with and think about..... here are a couple pics...... I will post instructions if needed..... pics pretty much explain it though.... the only real obstical are working with the curves of the trunk because the hinges in order to work right need to be positioned perfect..... as far as weight with spoiler.... with this mechanism/hing setup, wieght is needed on that side to keep trunk at a balanced level.... the hinge is setup to open only 90 degrees and not further..... as of right now our trunks open up a complete 90 degrees allready so countering the 90 we allready have brings the trunk back to zero which is how you get the level effect.... so no matter where you place the hinges you will allways be level with this trunk.... however the length of the "extra" piece is very important with this..... the length of the extra piece will determine how high up your trunk will sit.... my recommendation is the higher the better.... you are limited on the height to..... check out the pics.... this pic is self explanitory that one is an idea of the extra piece you will need to make.... this one is very important because it shows what I am trying to explain this is under the trunk cover..... if you notice the big hole.... I put my finger in the whole and there is about 1in or more of a gap between the inside of the trunk and the outside in that general area... so putting a couple screws right there should be fine as long as they are not that long..... check for yourself to make sure in order to keep from having a screw come out the top... this is basically what you will have when done..... microsoft paint is a pain let me tell ya.... lol .....
Old May 8, 2006 | 11:04 PM
po8pimp's Avatar
if you are worried about the wing because of this pic, don't be.... the trunk if you look at it origionally only opened 75 degrees or so when fully open therefore you have the extra lean towards the rear bumper.... not the case with our trunk because our trunks go completely 90 degrees..... wow after doing all this work I might try it out myself..... plus looks kinda sick....
Old May 9, 2006 | 04:23 AM
ramberg's Avatar
GrandPa
You are the man. Thanks for taking the time to explain this. I might have to drive to your hometown for the install.
Old May 9, 2006 | 07:54 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
you guys are silly, that won't work for our cars... I like the shocks way better than the arms any day, more room in the trunk and it looks way cleaner..
I did it on my 02 maxima and its cool, but that because it came with the arms, I will never mod some arms to my 6th gen..
Old May 9, 2006 | 07:56 AM
nismo0604's Avatar
talk to 03on18s about trunk hinges, he had one of those trunks, opened it at a mett and it shattered his back window
Old May 9, 2006 | 08:03 AM
Tek-Niq's Avatar
, I was there when it happened....lol..
Old May 9, 2006 | 10:01 AM
po8pimp's Avatar
that's why you make sure the fabricated arm is long enough for clearance....... and keep the origional hinges installed this will keep the trunk from flipping open fast like trunks without..... and tek I think you are wrong when you say it won't work..... give me about a month and I will post pics of it complete..... if someone does this sooner post pics so we all can see.... I was thinkin about designing a new hood to have fabricated.... any one have ideas..... I have a point of contact who might be able to make some if there was a group buy and cut a good deal..... the design is deffinitly the factor with this.... a plain carbon fiber hood is ghey.... and a waste of money.... I was thinkin something like the new gto or firebirds.... maybe even the Grand prix.... nothing like the evo.... that is ghey too.... no huge hood scoops just something sleek and satisfying.... let me do some more research on this and I will start a new post unless there is one allready created.... I will look....
Old May 9, 2006 | 12:22 PM
luigi'smax's Avatar
anything yet ?? ok ok it has only been three hours...but im excited.. .. lol
Luigi:
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
