Clicking noise from engine compartment
Old Mar 1, 2005 | 12:16 PM
s14gt's Avatar
Hi,
I have 05 Maxima and it's got around 1800mi so far. I love maxima!
Only problem I have is that I'm hearing this weird noise from engine when I put my foot on gas and keep it around 1500-1600 rpm. A clicking sound. The noise can be heard in 1st and 2nd gear because that's when it's slow and quiet enough.
I'm just wondering if anyone had this experience or knows what this could be. Hopefully this won't get aggrevated as it ages...
Any input would be appreciated.
Old Mar 1, 2005 | 12:59 PM
msoemax's Avatar
LOL
Me TOO...The Nissan DTS said no problem found. Good...it sounds like a rattling sound right. Happens in second gear at 1800 RPM and also under greater torque/load at 2800 RPM. Similar sound but more of a buzz. Let me know...I may start a poll to see if it's a common issue. There is a TSB regarding the heat shield.
http://www.infinitihelp.com/Ownershi.../NTB04-019.htm
that may be part of the problem, but I doubt it...
Old Mar 1, 2005 | 05:49 PM
s14gt's Avatar
This may be it... It's just weird that I can hear it only at certain rpm range. It can be only heard around 1500-1700rpm and 1st or 2nd gear. Usually when I'm driving very slow through parking lots. I'll take it in this weekend and find out.
Thx alot
Old Mar 1, 2005 | 05:51 PM
s14gt's Avatar
I'm not sure if I hear anything at 2800rpm... I haven't rev'd past 2500rpm many times... but I'll try that and see if I can hear the same noise.
Old Mar 1, 2005 | 05:53 PM
Jayzmax04's Avatar
Mine does the same! The dealer of course cant find anything. Wish I could grab a tech and keep him for a day....
Hopefully someone will see this thread who has gotten this fixed.....
Old Mar 1, 2005 | 06:59 PM
SLuxury's Avatar
If it's doing it in a narrow rpm range, it's most likely something loose that's resonating at that frequency. It may very well be the heat shield.
Old Mar 1, 2005 | 07:54 PM
Monotaur's Avatar
Many of us here have had a lose heat sheidl that resonated at around 2K RPM... it took my tech all of about 5 minutes to find it (although, they can never find any of my other problems...).
So, I agree - it is most likely a lose heat shield.
Old Mar 1, 2005 | 08:02 PM
wsu's Avatar
wsu
metallic rattling vibration
My 2005 SL makes a fairly high-pitched, low volume metallic rattling vibration through a certain RPM range. It seems to me that it is the resonant frequency range for some part. I can feel the vibration through the accelerator peddle.
I have taken it to the dealership and they have confirmed the situation (both the salesperson and one of the mechanics acknowledge the sound and vibration), but have been reluctant to diagnose it further. They want to sit on it as long as it isn't manifesting any other effects. As far as I can determine, the sound is not associated with any impact on the car's performance or operation. That said, I'm not comfortable with the sound in that I wonder if it is something that is wearing out that will make itself know after the warranty is out. I have been insistent with the dealership regarding nailing down the source of the sound and have a service appointment arranged in the indefinite future for them to do so. I plan to post the source of the noise when it is definitively determined.
Old Mar 1, 2005 | 08:44 PM
lightonthehill's Avatar
s14gt - Do you ever hear the clicking when the car is rolling slowly between parked cars or next to a wall while coasting out of gear? If so, the click is coming from the chassis/wheel area, not the engine. If the click seems to be about once per wheel revolution, it will be in the hub area (probably the front hub). This type of click was reported here several times a year or two ago, and, IIRC, it turned out to be nothing to be concerned with.
Do you ever hear the clicking when the car is not moving, the tranny is in neutral, and the engine is turning around 1500 to 1600 rpms? If so, the click is either the engine or something attached to the engine.
I suspect the clicking is there at higher speeds, but cannot be heard because of either wind noise, or lack of cars/walls right beside you.
Put on your Sherlock Holmes hat (or agitate your Hercule Poirot little gray cells) and do a little detective work. I would bet you can narrow things down to a very small clique of suspects.
Old Mar 1, 2005 | 10:21 PM
tototee999's Avatar
Originally Posted by msoemax
LOL
.. i think he was talking about the 2005 maxima.. you guys are talking about the 2004
Old Mar 1, 2005 | 10:34 PM
SouthStar019's Avatar
i have a 04 and i hear it at times.
Old Mar 2, 2005 | 02:41 PM
s14gt's Avatar
Thank you for very helpful comments folks.
My previous hauler (96 240sx) made a clicking sound from the wheel/hub area, so I know what that sounds like. That said, I doubt it is from wheel/hub parts, (it is only obvious during at certain rpm range, whereas wheel clicking sound lasts until your ear is filled with wind/road noise), but now, thanks to lightonthehill, I can confirm where the sound is originating from.
Old Mar 2, 2005 | 02:56 PM
Jayzmax04's Avatar
My noise is definately not in the wheel/hub area.
Its only when I accelarate, from about 5-30mph....not coasting or braking. Something is clicking and creaking in there, cant figure out what it is!!
Maybe the heat shield??
Old Mar 2, 2005 | 03:14 PM
msoemax's Avatar
It won't make the noise unless you are in gear, 90% of the time it happens in 2nd, and the engine is underload.
Old Mar 2, 2005 | 03:27 PM
kmoney56's Avatar
I had the exact same problem (sounds like anyways) and after taking it in about 8 times, they found out it was one of the catalytic converters. It had something loose inside of it. They replaced the Y-Pipe (which includes 3 cats, I believe) and it was finally fixed! Before they found the problem with the cat, I had them do the heat shield TSB and it did nothing. This might be something to look at if they can't find another apparent cause...
Old Mar 2, 2005 | 04:28 PM
Jayzmax04's Avatar
Kmoney, did you have to replicate the sound for them? Was it hard to get them to admit there was a problem?
Old Mar 20, 2005 | 07:37 PM
msoemax's Avatar
Lookie lookie
An answer for us!!!
F#$king Nissan making me feel stupid and wrong!!!
Old Mar 21, 2005 | 08:36 AM
Jayzmax04's Avatar
Msoemax,
Where did you get this? Did this come FROM Nissan? It looks like it, but not sure.
I would LOVE to take this to my service guy and shove it in his "we cant find it" face.
Please reply!
Old Mar 21, 2005 | 09:08 AM
msoemax's Avatar
http://www.nissanhelp.com/Bulletins/Maxima/2004/1.htm
These can be found on the TSB sticky....look there often for issues. I would love it if you could take a video of you sticking this down the Service advisors throat. This was the last straw with Nissan...
I am in the process of BBB arbitration, which i am sure will not yield the desired results. So I am getting my lawyers ponied up. Got to love finds like this one that just stick it to Nissan hardcore....I am so pissed at them
alahjahwan09
18
Sep 21, 2015 09:12 PM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
maxfever1987
Sep 6, 2015 06:20 PM
jfl330
Sep 4, 2015 01:44 PM
