Installing Sub's
Installing Sub's
I wanna install my amp ans subs from my old car, but I wanna hook it up to the stock radio. I need to know what modal PAC let me run the rca outputs to my amp. I know its been said on here before but I cant find it. Please help me out, Im gettin the need for some bumpin in my trunk. Thanks.
Originally Posted by Wakkus_Maximus
Where do I connect this?
This is exactly what I need for my Basslink install. The question is, anyone knows where is this hooked up to?
I've done this save some cash....
Originally Posted by MObruin
Get a line out converter. It converts your stock speaker wire into RCAs.
Check ebay, I got mine for 10bucks including shipping.
-MO-
-MO-
Ok but you have to splice your factory amp wires?
Where do you connect that?
don't scare yourself by saying splicing amp wires. it just the wires going into the rear spk's thats all...
Ok Niq now I read your other post... sorry to keep asking the same question. Anyway the Basslink is 200W RMS. I need a 200W H/L converter right?
I'm just checking here
http://search.ebay.com/line-out-conv...fkrZ1QQfromZR8
So you say that any of there will work for me?
if you don't wanna risk it on ebay just go to a local audio shop, they are cheap anywhere. 10- 15 bucks is all if you don't wanna wait.
Thanks a lot.. I'll keep you updated !!!
Originally Posted by Jeffs04SE
i just bought the PAC SNI-35 line out converter, that will work on my non bose max right?
Originally Posted by Tek-Niq
yea that will work. don't matter if its bose or not....
thanks for the quick response tek, my max will be the first car i havent replaced the HU in and i just wanted to make sure
When you splice the speaker wires, we need to make sure to do it to the wires coming into the Bose amplifier, not from the amp to the speakers. I believe that would cause some noise on the system, or the signal going into your second amp will not be clean, 'cause it will be an amplified signal, to be amplified again.
Sure, but I'm not taking the dash apart to make this mod. I'll just look for the right wire coming into the amp.
And Tek, to take the amp cover off (inside the trunk), do I just pull on the clips? They are really tight, and I don't wanna brake one while trying to expose the amp wires.....
Isn't the quality difference of using a hi/lo compared to one of the PAC AOEM-NIS2 a lot less since your tapping into wires rather than getting a signal from the head unit itself?
Another good thing about these PAC adapters is that it has a total of 2 sets of RCAs making hook up to two amps real simple...or am I mistaken.
I'm considering putting in a sub or two...but haven't figured out which way I wanna go. Hi/Lo or PAC AOEM-NIS2....Capacitor or no Cap...
I will also be scared to break something... go the safe way if you like..
**** SPARK .......... this is what I was running in my 02 max with a hi/lo adapter just fine...
Originally Posted by sparq
Teq---I guess if you're only using the signal for bass then a hi/lo is fine...but you'd get noise if it's for highs.
Your equipment probably had all kinds of noise filters in it anyway by the looks of it
I won't recommend any product if I didn't get it to sound good. had no probs ever with it. I did infact install two EQ's and 3 caps a crossover with 0 gauge wire power and ground. one amp and two subs. simple as that no problems..
Basslink's almost in. I have the power wire and ground wire secured, the basslink fixed on the trunk, still need to figure out which wire comes from the HU to the factory amp. The factory amp has a blue plug and a white plug, and like 45,000 wires on each...
Hi Tek, it's been a while since I had time to log into the forum.
Nope, I'm not looking for the remote, what I'm looking for is the wire that brings the Input signal to the amp. Since I have a Hi/Lo converter, can I tap into the wires going into the factory subs? The subs on the rear deck have this connection:
- left (driver's) sub : white, black/gray
- right (pssgr's) sub : white, black/gray, black (higher gauge), yellow (higher gauge)
Sure I'm going to try that... but is there a problem if I mix up the + wire with the - wire? I don't know if the positive is the black/gray or the white....
you got me there.......... sorry........... but good news is if you get it wrong you won't blow a fuse or anything, it would just sound wrong..... good luck..
Mike
Want a serious converter?
May cost more but believe me, what an impressive unit.
Also has an input for aux source (MP3, Sat, etc.)
It's the CLEANSWEEP by JL Audio.
May be too much for just adding a Basslink sub, but if you're looking for
high end sound, a must have unit.
Just ran into a setback with the Basslink, the power cable is too thick (#4) for the terminal on the basslink, so I'll feel better replacing it for a #8 wire, same size as the ground wire. Bad thing's gonna be passing that cable again.... I'll keep you guys updated!
MaxLife17
Jun 27, 2019 01:37 PM
