Steering wheel audio controls
On my SE with the Bose I am experiencing intermittent problems with the steering wheel controls. Sometimes when I try to change channels, nothing happens. I have to turn it off and on again to get the control to work. The volume control isn't affected. It used to happen rarely, but now it seems to be happening almost every day. Has anyone else experienced this problem? Does anyone know if the controls are wired, rf (maybe), or infrared(doubtful)?
I haven't had this problem with the Max yet, but my wife is on her third Pathfinder ('00, '02, '05) and all three of them have had a similar problem: the volume adjusts itself up or down at odd times without any input from the driver. I'm pretty sure the problem comes from the steering wheel controls, since it usually happens during gradual turns in regular driving. It never lasts more than a few seconds at a time.
Good luck getting it fixed. When you take it to the dealership to have it checked out, there is a ZERO percent chance that the problem will occur with a tech in the car. There is a 100% chance that the dealership will send you away without performing any fix, since they could not duplicate the problem.
It might be worth mentioning it to them anyhow; maybe they keep track of such reports in some big, secret computer somewhere.
Originally Posted by froMax
On my SE with the Bose I am experiencing intermittent problems with the steering wheel controls. . . Has anyone else experienced this problem? Does anyone know if the controls are wired, rf (maybe), or infrared(doubtfull)?
I believe the steering wheel controls are wired to the Bose.
Originally Posted by NismoMax80
have you called the dealer yet? if it happens that often, you should show them easily.
Originally Posted by jc53
. . . the bose system in the Max, I believe the system is designed to adjust the volume automatically as road noise increases or decreases.
sayaltitude
If your wife's Pathfinders are like the bose system in the Max, I believe the system is designed to adjust the volume automatically as road noise increases or decreases.
Problem continues...
I forgot to say in my original post that the problem occurs also when I'm playing a cd. Can't change tracks, but the volume control still works. Turn it off and then on again, and I can change tracks. So, there is some malfunction in the bottom button itself?
Fro - I'm having the same problem. The channel doesn't work but the volume does. I took in to the dealer and they couldn't reproduce the problem..Of course. It happen to me everyday but they couldn't reproduce the problem. So when it happen again later that same day I took it straight to the dealer. They ordered a new switch. I assured them that wouldn't work but what the hell...it's free. I'm sure I will be brining it back within a week for the same problem.
Had my audio control switch was replaced and it's still jacked up. I told them the switch wasn't the problem but hey, they're techs and I'm a dumb consumer. I will be calling to setup my fourth appointment in regards to this problem. Having said that I WOULDN'T TRADE BABY GURL IN FOR ANYTHING !!!
lowpost99
05-16-2021 11:18 AM
