Keyfob How Do I Program? 6.0 and older gens
How do I program my Keyfob? I have checked the manually, but I do not see anythiung and my dealer did not say anything about an intialization process.
Shawn
Shawn
naw, there is a way to do it yourself.. its a progress of sticking the key in the ignition acouple of times or something like that... but this can be done...
those ebay key fobs come with the program on how to do it...
I bought an additional remote on Ebay and these are the instructions that came with it. However, I haven't programmed it yet because the remote was damaged. I sent it back to the seller and he is sending me another. You can pick up these additional remotes from this guy for about 10 bucks plus shipping. Mine awas $16.00 total. Pretty damn good deal considering what a dealer will charge. Good luck.
6th gen Remote programming instructions:
1. Get in & lock the doors.
2. Insert the key into the ignition 6 times within 15 seconds.
3. Hazzard lights should flash.
4. Put key back into the ignition & turn to the run position but do not start.
5. Hit the lock button on the remote.
6. Hazzards should flash.
~If additional remotes go to step #7~
~No additional remotes go to step #8~
7. Unlock and lock the doors with the lock switch on the door and go to step #5.
8. Pull key out and open the drivers door and then close it
9. It should be set.
Remember if you have more than one remote you must program them all at the same time
Here's the link to the seller's store on ebay.
http://stores.ebay.com/Auto-Remotes-...Q3amesstQQtZkm
Originally Posted by erasat
Well if it's a Sticky, then I must check my Browser, because I'm still seeing it as a Regular thread.
http://forums.maxima.org/showthread.php?t=326195
Shawn
Shawn
programming info. let me know if you still need it, i'll see if i can
locate it
Has anyone been able to verify if the new 07 keyfobs work with other 6th generation maximas? They are selling them on ebay and I was wondeirng. I emailed the seller and he says they work because he has sold them to people with 05 maximas. The link is
http://cgi.ebay.com/ebaymotors/2006-...spagenameZWDVW
97_GXE
09-15-2015 07:47 AM
maxfever1987
09-06-2015 07:20 PM
