HELP!!! HID problem already!!
Old Apr 30, 2005 | 11:57 AM
HzMajesty's Avatar
Okay guys,
I just got the HID headlights installed. They work perfectly... except..!!!
Problem location: Drivers side headlight
Problem: Sheild for hi beam stays up even after i let go of hi beam!! Other is okay no problems. Whats up with this sheild? After flickering from hi to low beams a few times it lets go and drops... but then stays up if i hit the hi's a few times more...
Any ideas?
Dealer Solution: HID Unit Error-must replace
I dont buy that... he said there are 2 bulbs in the HID unit, 1 for hi and 1 for low.. i thought there was a sheild that exposes the full bulb when u hit the hi?! Am i wrong? He also said that i'll need to change the HID Unit (he means Ballast i guess) and bulb. Why??? they work fine!!! its just the fact that it gets jammed when i hit the hi beam...
any ideas guys?
I have my 2 normal headlights if that may help in any way.... HELP!
Old Apr 30, 2005 | 12:09 PM
NismoMax80's Avatar
SuPeRmOd
so i assume You installed oem HIDs? Some people have had a shutter stuck open. Under warranty the dealer replaces it. Seriously your Nissan Dealer said 2 bulbs? We only have one bulb w/ a shutter.
you really have no choice but to fix it yourself or buy a new setup. everyone else has it stock so Nissan fixes it with replacement.
Old Apr 30, 2005 | 12:14 PM
HzMajesty's Avatar
Exactly what i thought!! 1 bulb with a shutter! Useless service ppl. Okay, I installed full OEM HID headlights... shouldn't that be under warranty? I know its not the stock headlights, but if i go to another nissan dealer will they change it?
How would i go about fixing it myself?
What parts would i need to buy?
Thanx Nismo
Edit: Not only did he try to convince me that it was 2 bulbs for HID, he wanted me to order the ballast to get it fixed... WTF???
Old Apr 30, 2005 | 12:18 PM
NismoMax80's Avatar
SuPeRmOd
like i said, you would be the first and have to tell us. take it apart and play with it, lube the hinges or something, who knows?
Nissan only warrants what they sold you. You either A) need a friend or very generous service manager to "hook you up" or B) find an ignorant service dept. that ignores that your VIN reports halogen when the computer reports no HID parts for your vehicle.
well yeah the dealer will try to make $$ off of you. part replacement is illogical sometimes. it may just call for entire system to be replaced.
Old Apr 30, 2005 | 12:20 PM
HzMajesty's Avatar
ok heres a question... can I use the shutter from my halogen headlight? Just a quick replacement and everyone lives happily ever after?
Old Apr 30, 2005 | 12:29 PM
04BlackMaxx's Avatar
Go onto HIDPLANET.COM...
they have forums and know the intricate details of our Hella projectors and their mods are as helpful as they get...these guys know their stuff and take apart units just like ours.
Old Apr 30, 2005 | 12:30 PM
NismoMax80's Avatar
SuPeRmOd
that has been brough up before, and it was left at they are different metals. the bulbs are also different shapes. it's really left up to you to find all this out for sure and figure it out.
have you tried contacting who you bought these from? how were they obtained? are they off a wreck, replaced b/c defective, or stolen? maybe they can help you with a replacement (doubtful) or get you a new shutter.
to fix you will need to risk opening them.
Old Apr 30, 2005 | 12:44 PM
HzMajesty's Avatar
Posted problem on HID planet... refreshing page constantly...
Headlights from a wrecked Max... no replacement.
Praying for a solution....
Old Apr 30, 2005 | 12:52 PM
NismoMax80's Avatar
SuPeRmOd
wait patiently on the HID site, but maybe search for any similar info and contact people. meanwhile don't use the high beams. I hardly ever use them.
like I said you're likely the first to have this problem w/o warranty.
Old Apr 30, 2005 | 12:56 PM
HzMajesty's Avatar
Thanks for the help guys...
meanwhile.. ima go buy a new toolkit... gonna need thinner screwdrivers for this....
btw.. is this what im gonna have to replace: Bosch Xenon D2S Projector
Old Apr 30, 2005 | 07:11 PM
HzMajesty's Avatar
i got a reply on hidplanet... problem has been identified with a possible solution.
http://hidplanet.com/forums/viewtopic.php?p=63850#63850
however, how on earth am i gonna get the projector out without taking the entire headlight housing off? (dont wanna do the whole bumper removal thing again)
If i get it out and still cant fix it, will replacing the projector fix this? (ie. is the sheild part of the projector?)
Old Apr 30, 2005 | 07:27 PM
NismoMax80's Avatar
SuPeRmOd
that guy seems to know his stuff and is your best help on this. Why do the posts say "May1 10:24am" lol Anyway, I would try to locate the projector online or from another wreck. or see is DAVEB can get one. pm him. he is the Org Nissan parts supplier. you're gonna have to do some surgery again to take everything apart.
or check eBay for a headlight
Old May 1, 2005 | 04:44 PM
HzMajesty's Avatar
Okay, i got the sheild to come down with a little tapin on the inside case and a lot of hi-beam flicking...
Im gonna level them, then leave it like this without using hi's until i find me a new projector. I prefer replacing than fixing.. shes to precious!!!
if any of u come along a projector.. plz let me know.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
