6th Gen Rotor Recommendation
Old May 15, 2005 | 02:14 PM
ABS's Avatar
ABS
I'm looking to upgrade the brakes on my 5.5 gen Maxima with 6th Gen parts - (I've already confirmed that this will work). I am hoping that someone could recommend to me some light weight 6th gen rotors? The OEM rotor on the 5.5 gen is around 16lbs. and I'm told the OEM 6th gen rotor is around 22 lbs. Any help with this would be appreciated. Note the rotor does not need to be x-drilled or slotted, but it is also okay if they are. Last, I don't want to pay a ridiculous amount of money. The idea is for me to buy a big brake kit for cheap.
Thanks!
Andrew
Old May 15, 2005 | 06:45 PM
Maximam's Avatar
What you are asking for is why you have your problem. The reason the 6th gen rotors are better not only because of a larger diameter which has its leverage advantages but the added mass reduces warping posibilities.
Without reducing performance to go lighter would require a different material.
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Oct 25, 2015 08:27 AM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
