Service Engine soon Light goes on at 15k miles
Old Jul 5, 2005 | 07:40 AM
xorbitman's Avatar
My "Service Enginer Soon" light went on a couple of days ago. I have no clue why that happened while I have been doing the oil changes on time and the car is only 8 months old and has only 15K Miles on it. Any ideas?
Old Jul 5, 2005 | 07:45 AM
darrinps's Avatar
This is just a guess, but you have a CAI right? Does it use an oiled filter? If so, you might check to see if there is oil leakage that has messed with the MAF sensor.
You also might want to take your car to an Autozone (or somewhere else that will do it for you) and have them pull the error code to see what is going on.
Please report back here when you find out what it is.
Old Jul 5, 2005 | 07:47 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Is your gas cap on securely? Do any Mods? Check the owners manual, they have a troubleshooting section which states why this light may come on... Good luck and let us know what you find...
Old Jul 5, 2005 | 09:18 AM
xorbitman's Avatar
Thank you guys for the tips...I will keep you posted.
Old Jul 10, 2005 | 10:05 AM
xorbitman's Avatar
Hi Guys,
Found out it was the EGR Valve and the Cat that need to be changed. There is a technical bulletin about this too.
http://www.infinitihelp.com/Ownershi.../NTB05-037.htm
By the way Chermax, that's a smokin' ride you got there! Woah! Ouch very hot!
Old Jul 10, 2005 | 10:07 AM
xorbitman's Avatar
Going in on Wednesday...parts in T.O. (Toronto, Ontario)...all on warranty. Phew!
Old Jul 10, 2005 | 05:23 PM
darrinps's Avatar
Hi Guys,
My gosh!
Where in the world was the quality control on that? How could you have something with metal debris in it like that get through?
Old Jul 12, 2005 | 12:40 PM
Davidx34's Avatar
Dealer is the best way to go
Just take it to the dealer, thats my two cents
Old Jul 14, 2005 | 12:13 AM
xorbitman's Avatar
Dealer checked valve...no debris...now doing back pressure check regarding Cat. I will use this opportunity to ask about advancing the timing 2 degrees to 17.
Old Jul 14, 2005 | 04:04 AM
maxmale's Avatar
also while your down there might as well get the greddy.
Old Jul 15, 2005 | 07:42 AM
xorbitman's Avatar
Hi Maxmale ...love your ride....I have a few questions: regarding the seats...did you put those in yourself or did you have that done and looks real cool. How did you do that paint job in the engine bay? Whose Intake is that? Is that the full Cat back from Greddy? DId you have that done at the dealer?
Regarding my Max, the CAT was OK and did not need changing. The dealer did change the EGR valve though because the Nissan Tech Center recommended it. I have the car back and she's doing great. A bit of vibration around 70 mPH ...maybe time for a wheel balancing again....next oil change.
The dealer said that they were not equipped to advance the timing....Strange. Oh well at least I tried.
Old Jul 20, 2005 | 01:41 PM
Ankit69's Avatar
my car has gone 18k miles and the light just turned on today... i have no mods in it except like tints so i have no idea why this light went on?
Old Jul 20, 2005 | 02:05 PM
04BlackMaxx's Avatar
I been lucky...SES never went on till I dropped a K&N in for a few mins....took it out...it stayed on for a couple days and hasnt been on since...BTW I have 37k now
Old Jul 20, 2005 | 02:11 PM
RHMax's Avatar
Newbie just Registered
I'm running K&N since I got the car and no SES light. Are you sure that K&N was the problem?
Old Jul 22, 2005 | 02:07 PM
Retep01's Avatar
what is the best air filter around that will add the most HP? Sorry i cannot start my own thread yet b/c i am under 15 posts.
Old Jul 22, 2005 | 11:11 PM
RHMax's Avatar
This topic has been beaten to death witn no real winner Look through past threads.
Old Jul 23, 2005 | 05:11 AM
Im positive...immediately at startup with the new K&N in it went on and the revvs were all messed up at idle...took it out and the car revved fine and light went off after 3 days...
Old Jul 23, 2005 | 06:42 AM
daves04smoke's Avatar
The "Other" project
RH,
Same with me have had the K&N from 50miles on and no SES light, question for 04Black, did you add and of the spray oil on the filter?
Old Jul 23, 2005 | 07:27 AM
Nope...I took it out of the plastic and popped it in per the instructions.
Old Jul 23, 2005 | 10:31 PM
RHMax's Avatar
I had a tough time locking the air box the first time w/ K&N. Since then, I removed the air box several times for different mods, and still no light. Do you still have it? Do you want to try it again?
MatthewsMaxima
Sep 11, 2015 03:21 AM
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 11, 2015 12:53 PM
