6th Gen Oil & Lighting Info
Old Oct 12, 2005 | 08:28 AM
MAXIMA-GHOST's Avatar
Here is a compiled list for you guys.
2005 NISSAN MAXIMA 3.5L 6-cyl VIN Code VQ35DE
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API* from http://www.amsoil.com
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
All Temps......5W-30[1]
Manual Transmission,.....GL-4
75W-85
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission,W/ 5-spd.....SLF[2]
Fluids
Power Steering Fluid.....AF3
Synthetic Automatic Transmission Fluid
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Brake Fluid.....HB
Clutch Fluid.....HB
1. SAE 5W-30 is preferred.
2. Use Genuine NISSAN Matic K TRANS fluid.
CAPACITIES
Engine, with filter..........4.5 quarts[1]
Cooling System, Initial Fill..........9.0 quarts
Automatic Transmission, Total Fill
5 speed ..........7.7 quarts
Manual Transmission, ..........4.6 pints
1. After refill check oil level
TORQUES
Oil Drain Plug.....22-28 ft-lbs
Manual Transmission
Fill Plug.....23-28 ft-lbs
Drain Plug.....23-28 ft-lbs
Here is the Lighting...
HID Xenon Set-up
HID-D2S
Fog/Driving Lights
H3-55W
Parking Lights
1157A
Front Turn Signals
1157A
Rear Turn Signals , Tail Lights & Stop Lights
3057LL
High Mount Stop Light
2825
License Plate Light
168
Back Up Light
3156LL
or 912
Cornering
3156LL
Rear Sidemarker
168
Glove Box
158
Map Light
DE3021
Dome Light
DE3175
Step/Courtesy Light
194
194LL Long Life: Twice the Life of Standard
or 2825
Truck/Cargo Area
158
Daytime Running Lights
1156
1156LL Long Life: Twice the Life of Standard
Just thought you guys would like a list just in case you are out and about..
Later....
homeyclaus
Sep 3, 2015 06:15 PM
4 door GT-R
Aug 22, 2015 07:50 AM
maxinout93
Aug 20, 2015 02:17 AM
Maxgig
Aug 18, 2015 09:17 PM
